K'nex Pistol Repeater
PlayKnex by
1,883
4
26
Posted
Introduction: K'nex Pistol Repeater
This is my first k'nex pistol i've built. It gets really good ranges, and is very durable. It has a strong trigger and frame so you can lay on the elastic power. The trigger has never faultered, nor has the gun jammed. It is so reliable because of the way the barrel is made. It doesn't hold the as many rounds as other pistols on the site. The hopper holds 3 rounds.
This gun was actually born because my friend said to me "I bet I can make a better k'nex gun than you". I said ok lets have a competition. The rules were to built a pistol within 2 hours. We set up a wall and started building. The wall prevented the both of us from stealing ideas from each other.
He built this weird funky thing, and I built the pistol shown in the instructable. He said "wow I didn't think you were that good".
Have fun!
Step 1: Piece Count
This gun doesn't use alot of pieces, so any k'nexer should be able to built it. The counts may be off by a few pieces. It should be pretty accurate. Leave a comment if any of the piece counts are wrong.
RODS:
green: 42
white: 38
blue: 2
grey OR black rod: 1
CONNECTORS:
white: 18
yellow: 13
orange: 6
dark grey: 9
light grey: 5
tan clips: 4
blue end cap: 1
hinge: 1
MISCELLANEOUS:
black Y connector: 7
blue spacer: 2
tape
Total: 146 parts
Step 2: The Barrel
Lets start off by building the barrel. It is a bit challenging putting it together, but you can get through it.
1. Build the side panels.
2. Gather 11 white rods.
3. Attach the white rods where shown.
4. Build the internal parts for the barrel.
5. Add the internal parts you made.
6. Make sure the blue end cap is here.
7. Add the panel.
The barrel is very flimsy, but it will be solid and strong once you add the body.
Step 3: The Body
Now we'll build the body. It's really easy.
1. Build these panels.
2. Gather 3 white rods.
3. Add the 3 rods where shown.
4. Add the middle panel.
5. Add the outer panel.
Was that hard? Next step!
Step 4: The Trigger
Now we'll build the trigger. It's a little clunky but it can hold alot of weight.
1. Build this and save it. We'll use this in step 6.
2. Build the parts for the trigger.
3. Attach the light grey connectors to the dark grey connector attached to the white rod.
4. Attach the blue rod.
5. Attach the hinge connected to white rod to the blue rod.
6. Attach the dark grey connectors with the Y connectors to the blue rod.
Step 5: The Handle
you're almost done! Build the handle now.
1. Gather and build these parts.
2. Attach both white rods where shown.
3. Attach the middle panel.
4. Attach the outer panel.
5. Add this.
6. And on the other side do the same.
Step 6: Final Assembly
Time to assemble the gun. You're almost done.
1. Build the ram.
2. Gather everything you built.
3. Attach the barrel to the body.
4. Attach the Handle the the rest of the gun.
5. Put the trigger on by using the part you built earlier.
6. On the flip side, add the space and tan connector.
7. Make sure the white rod goes through the gap into the barrel.
8. Slide a rubberband through the hole.
9. Put the rubberband here.
10. Same on the flip side.
Step 7: How to Load, and an Important Thing I Forgot to Add.
You must add this, if you don't the barrel will just blow up.
1. Put tape on.
2. Put ram in gun.
3. On the other side of the gun. add 2 green rods.
4. Put tape over both green rods.
5. Put a rubberband here, it loops around the whole gun.
6. This is how it should look where the ram enters the barrel.
7. Gather 2 rubberbands of you choice.
8. Wrap one on top like this.
9. Add the one on the bottom.
LOADING AND FIRING:
1. Cock the gun.
2. Gather ammo
3. Put them in and rubberband them down.
If you want to, you can shoot the pusher, but it will fall out if the gun is aimed down.
Step 8: Finished!
You're done building! Just don't shoot at anything important like shooting your dog, or your neighbors windows and stuff. Rate and drop a comment. Thank you for building.
Should I post my other pistol I built? Here is a picture:
  • Sew Warm Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
26 Comments
i love ur gun but dont post the otha 1 cuz i love the original betta
I am new to this, so i have to ask, what is a hopper?
i need some k'nex gun instructables to start me out plz send me some
If I did this, the first picture would be my friends gun, and the second picture would be mine, lol.
Wow LoL. That gun looks like it was rendered with some kind of software. Did you actually build it?
It's my Z35, I made a real knex one and then made a computer model, instructions will be coming out soon, check out my YouTube video or slideshow to learn more.
Looks pretty cool. You think I should post my new pistol? Here is a picture:
Yeah, it looks good, I'm trying to design a machine gun at the moment.
Good luck, they're kinda hard to make without making alot of individual barrels while still making it look good.
Thank you, I will be using Extreme Builder's full auto mechanism as a base, making the structure multiple times stronger and adding a new mechanism for the power source, I have had the idea for over a year now, I made one attempt at it months ago, but now that I have more experience and have done some drawings, brainstorming, and work on a 3D model, I decided to have another go at it.
