Introduction: K'nex Pistol V2 Even MORE Updated
Super sweet k'nex block trig. pistol, mag can hold 16 rounds, virtually never blocks, really stable, sweet design, everything you could want. It can take a lot of pressure, so pile on the elastics. shoots blue rods the lenght of my house and farther. so maybee 50 feet or so depending on the amount of elastics.
+ slide out barrel, for easy change in lenght, etc. (check out the vid! (sry for the late post))
Works on the same mecanism as the old version, you can build it based on the pics, improvise, its not that hard.
On this vid, i think there are only 14 rounds in the gun, but it can hold 16. You can see the slide off barrel, witch lets you easily take it off, mod it, etc. I only have a few elastics on the gun, but its already quite powerful.
Step 1: Handle
This is the handle, it's pretty simple yet comfortable.
Step 2: Barrel
This is the barrel of the gun, it can be easily modded. (The black piece is for better aim.)
Step 3: Main Technical and Intergrated Magasine
This is the cool part: although the gun appears not to have a mag, it can actually hold 4 blue rods!
Step 4: Assembly
How to put together your gun: The handle clips right in to place, and so does the barrel. Simple!
Ram rod: A orange rod (same lengh as a red one) slide in a grey spikey piece, followed by a beige piece with extension pointing to the back of the gun, then slide a blu ring and finally, a orange connector. It should fit right in under the beige extension.
Slide the ram rod right in the back, the only hole there is.
Nox for the elastics(next step)
Step 5: Elastics
the more elastics you put on, the more powerful your gun will be!
First, double loop the small red one, then strech it from the end of the trigger, through the gre piece then around the other one sticking out of the other side of the gun. Then add the rest of the elastics, from the tip of the orange connector at the end of the ram rod to the front of the gun. Make sure it doesn't get in the way of the exit of the barrel. Take your 3 blue pieces, and push them right in the mag, like seen in the vid. You're done. Have fun!
This is a pic of the guns loaded, they can hold 4 blue rods. The handle is realistic, although it's a block fire, the grip feels awsome. Watch the vid!
