3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Knex sniper rifle
Knex sniper rifle
A knex sniper rifle. If you can give me any ideas for a good bi pod or tri pod let me know. This is a RBG can fire like a shotgun firing 2 shots at ones. This is not semi automatic.
Here is a link for some mods http://www.instructables.com/id/Knex-sniper-rifle-mods/
Good
easy to make
powerful
sturdy
Bad
trigger breaks
fires a little high
Step 1Barrel
Barrel
The barrel.
1. make 2 of these 1 without the oranges.
2. the other side
6 comments
Aug 4, 2011. 12:35 PMyounglink212 says:
gonna build gonna be EPIC!!!
Dec 27, 2010. 3:44 PMpodmod says:
i changed the stock so it was comfy :) i used 2 neon yellow rods .
also is this a rubber band gun MADE of knex or does it actually fire knex ?
May 22, 2010. 12:34 PMknexmaster99 says:
put a tri pod onto it by attatching a female connector onto the bottom of the barrel and then get those blue connectors that you slide together and slide them together then attatch the desired amount of rods either 2,3 or 4. then on the to put a male connector and then attatching the male and female together. if you did it right you should be able to move it in many directions.
Sep 29, 2009. 10:59 AMMrmazza says:
how do u load and fire it
Sep 20, 2009. 8:40 AMfiredog says:
i made it but i changed two pieces to put a bipod on the front
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Shadowpom
