Knex Button Activated Grenade Launcher
3,432
4
67
Posted in PlayKnex
Introduction: Knex Button Activated Grenade Launcher
This does NOT use a block trigger.
Ranges:10 to 15 feet
Can be mounted on any gun.
Step 1: Parts
Vary small amount needed
no rare pieces
Step 2: Ram and Trigger
Make both
Step 3: Barrel
make
Step 4: Assmembly
Picture is for right handed people.
If your lefthanded put the black piece on the other side.
Step 5: Rubberbanding
Add rubber band
Step 6: Firing
When you pull back the ram the trigger will slip into place.
Then push it in to fire.
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    67 Comments
    technically every gun on sight is block trigger because every gun has something to block the firing pin
    not all of them
    ya your completely wrong, there are plenty of guns that use whats known as a sear system which is the complete opposite. oh ya and has anyone noticed that people are posting "grenade launchers" that look eerily similar to crappy block trigger guns
    ? sear triggers are still blocking the firing pin
    no they arent they hold it back thats not blocking, block would mean to get infront of it.
    this is exactly true......kind of. all knex triggers are technically BOTH block and sear, being that an object "blocking" the pin at some point must move in a "searing" action to allow the gun to fire. but the main point is like you said, a "block trigger" here is one that has something in front of the pin to hold it back, whilst a "sear trigger" is one that holds on a small latch type mechanism on the rear of the pin. sear triggers are notably more difficult to design, however they do produce much better results in firing. (they also very rarely break firing pins!)
    its blocking its path by getting in front of at least some part of the pin
    A trigger that is a block trigger blocks the pin from the front; this is the term that we have adopted. You're getting too literal with the term. Block- blocks from the front. Sear- holds from the rear.
    the whole point of a term is that it is literal! I know wht they are
    The whole point of the term is to identify a part of a gun. When playing tug of war, and you are holding the end of a rope with a knot in it (hand in front of the knot), you do not "block" it, you hold it. The same goes for a sear.
    Not all, but most.
    yaaa.
    err, not every gun is. My crossbow uses a ratchet slingshot system. RBGs are not blocks either.
    yes rbgs are technically, they got some sort of mechanism that blocks the cog from turning.
    Some RBGs don't even have cogs or gears, but instead are more like a sling shot.
    someone already said that. I meant guns like this!!
    sear system guns are like this but they lock the firing pin in place, look up knex p90 desechos by M16.
    nope. what about guns that don't have firing pins? or true semi autos?
    this gun is a block trigger, not a push trigger where the heck did he get that from?
