K'nex Combination Lock
21,559
63
122
Published
Introduction: K'nex Combination Lock
This is DarthVader giving you a combination lock and my second instructable!
EDIT: wow, its been a while. my friend asked me to tell you guys that this is not my lock, i posted it for my friend a while back. this and the grabber. sorry, i didnt know he would ever be on this website, and i didnt know anybody even cared still lol, but apparently ppl still do! but yeah, this isn't mine. i just took the pictures.
Step 1: Wheels
These are essential to the combination lock!
Step 2: The Pin
This isn't essential, but it does add to the combination lock. Without it, your combination lock is a lot more dull... You'll see what I mean when you finish. Hinges work much, much better than ball socket and ball joint combinations! Try using older ones, as newer hinges tend to stay in the same position, whereas older hinges are more affected by gravity, being worn down and all.
Step 3: The Side Plates
These keep the combination lock together. Build 2.
Step 4: Connections
Connect the wheels to a rod, add spacers, and add to the plate. Connect the pin to the plate. The spacers in the second picture to the wheels (plate to end of yellow, or left to right): One, four, four.
Step 5: Add Second Plate and Customize
Add the plate and customize the wheel and the lever (for the pin). I used tan connectors to hold the yellow rods in place on the back.
Step 6: How to Make It Work
I don't own a video camera, so I can't post a video, but I'll try to explain how to set up your combination lock as best I can: You know those ball sockets on the green connectors? You rotate one on each white connector so that it interlocks with the ball socket on the wheel next to it. The middle wheel will require two ball socket rotations because there are two wheels next to it. Also, make sure that every single space (Green rod with no ball socket attatched) is lined up first, or else it will be pointless. Hope that helped! If anyone understands this and has a video camera, please demonstrate. Thank-you!
    • Stick It! Contest
      Stick It! Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    122 Comments
    this guy doesn't have 20 pieces... therefore the noob.
    Hehehe.... I can crack a lock by shooting it apart with a sniper rifle xD
    lol, i can use my SABR on it. it won't stand a chance from 10 feet
    Unless you find another way, yup.
    uhh how about you make it a little bigger, make the wheels squares made from white rods and red connectors, -1 rod on one side of each wheel.. would that work, do you think??
    And the wheels would have a white connector in the middle.
    I built it, he posted it. That wouldn't work because it would be too bottom-heavy, I tried it. It's a shame a video was never put up.
    i don't know what you tried but i saw many people do square tumblers that worked. anyway, check out my safe (ASKUS) for a real knex safe with big wheels and an actual safe to go with the tumblers and pin.
    Why, because you don't know how it works?
    on looks of it.
    I don't understand -at all- what you're trying to say.
    just never mind
