Knex Gun 2
1,004
Posted
Introduction: Knex Gun 2
a small hand gun that surprisingly has a powerful shot, i made it after i made the long wwii gun. Hopefully this one will be a better gun than the other go ahead see my instructable.
comment comment comment please tell me what I need to improve, show me your Instructables, ask me questions on to post yours or not, and please suggest new ideas like a new mechanism
i always use the mechansm you see on the side to trigger the firing pin i dont know any other way teach me and plaese comment on my work
Step 1: What You Need
i understand i didnt show you all the pieces you need in one step it must've been hardto do not knowing what you need, so im putting ALL of what you need in ONE step
the only pieces you sholud have a hard time with is the light green connectors and the conn, with the ball at end in the last pic the rest is easy to get.
Step 2: Starting to Put It Together
in these i will literally show you step by step what and how to put it together slowly so that it is easy to follow the pictures.
this will be part one, i dont want to jam it all into one step
Step 3: Starting to Put It Together
the second part to building the gun and were almost there to the end of the gun making!!!
after the fifth picture you hook the ends on the rubber band onto the little ball there, sorry my computer deleted them without me knowing while uploading them on to it.
wait for the finish...step 4
Step 4: The Last Thing to Do
this will finish the gun finally!!!
you can add a small connector to the white ammo to make sure it doesn't poke any eyes out, the green little rods on the handle are used as ammo shorter but easier to shoot have fun and I'll see you in my next Instructable!!!!!!!!!
i always use the mechansm you see on the side to trigger the firing pin i dont know any other way teach me and plaese comment on my work bye!!!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    8 Comments
    JSYK, you could get a TON more power out of this if you made the barrel connectors longer, moved the trigger closer to the handle, used a longer firing pin, and hooked two bands together and hooked their ends on the very end of the barrel area.
    shoots hard but is easy to carry 4/5
    i think this is good too, except both your guns are missing a vital ingredient - a true trigger! try to put on the one on the "Desert buzzard slide pistol", because that one is simple. I rate this 4 stars because it looks good.
    hey i made a gun that shoots rubber bands check it out
    At the very least, put a trigger on it. A simple mag wouldn't hurt either... Besides that, it loox pretty powerful.
    There is a trigger on it... you see the block trigger (orange connector)? Its at the very front of the gun!
    might want to put the trigger up higher on the gun. and try to use gray rods for the barell next time.
