Knex Gun
3,395
Published
Introduction: Knex Gun
a long knex gun, i made dont be to harsh, i know that this gun isn't top notch in the list but a. i dont have very much knex to use and b. im just experimenting with my guns. So well here it is, my gun. this is a gun that i made yesterday and it's not my first. thank you for looking
Step 1: Handle
well start easy, in this step well need
8 green connectors
2 yellow rods
1 blue rod
put it together
put 6 green on the two yellow connectors as shown
then the blue connector as shown
the pictures should be clear enough to use as an instruction on how to build it.
Step 2: Back Trigger
the trigger that you will use to activate the gun, fist you'll need
6 green connectors
3 yellow rods
3 yellow connectors
3 gray connectors
1 blue rod
2 green rods
put it together
begginning of two rods put a green conn., gray conn. on right yellow rod, 2 more green conn, 1 more gray conn., 3 green , and 1 gray connector.
on first notch on each gray conn. put the yellow rod on and attach yellow rod (or gray in my case) at end.
basically the rest should be according to the picture
Step 3: Front Trigger
you need
5 green connectors
2 light green connectors(note : these hold more support when putting ammo if you use regular green connectors the ammo will just slide out)
1 orange connector
1 yellow rod
2 red rods
3 green connectors
2 black half connectors with the ball on top(i have no idea what they are called)
you think you can build it using the pictures only?
its easy
Step 4: Bayonet
this will make the gun look like a WWII gun which is essential to the look.
you'll need
4 blue rods
2 yellow connectors
hopefully you'll be able to put it together based on the pic
level: easy
Step 5: Second Handle and Firing Pin
this will help you hold the gun and stop the wobbliness of the gun itself.
firing pin is well the thing you pull back to activate the ammo
second handle: two yellow connectors, 2 red rods, and the two little black rods with handles (optional still works same way)
firing pin: blue rod, gray connector, rubber band
Step 6: Putting It All Together
that's what a handle to back trigger looks like in first and second pics
this is the front trigger and bayonet being put together in the third picture complete in the fourth close up in the fifth pic
part underneath in the sixth picture.
7th-putting the second handle on
8th-done putting it on
9th-finished product
10th-parts in one next to each other, ready for the last step??
11th- putting in the firing pin
12th- putting in the rubber band
13th-the look of it when in
14th-Done
15th TADA!!!!!!!!
    • Pets Challenge
      Pets Challenge
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    18 Comments
    Were you drunk when you wrote there directions?
    howda u shoot?
    cool but too much green rods-i didnt have that much
    how do you fire and load the gun. As in, WHAT do you fire and how.
    cool just made it in 15 minutes , thanks
    super funny!! i made im it was a perfect gun i made the bischoff 720 A.T.V. to they're both super cool the bischoff is going fast!!! this one too!! thank for the instructions!
    Its a nice gun,I re-made the handle after the red cut me Its a 4/5 Pros a longer gun nice side trigger cons flimsy at times o.k accuracy
    ive just made it and its got about the same distance as no username's easy knex pistol
    thanks that means alot i mean i making another instructable now on a small hand gun check that one out as well
    this gun is mint (cough cough:)
    by the way, you can reply to a comment by clicking the reply button by the bottom right corner of the comment. this will allow the original poster to know you are talking to them.
    well... it's okay, at least it has a handle and grip, but it is small and by the looks of it a block trigger, which might not even work. I say you could make a better handle, then on those yellow connectors in the middle with the 2 green rods, form a lattice frame like on my guns, then you could try to make it into a large gun like my storm 220. I rate this 3.5 stars for effort, because unlike many small guns on this site, you added some features like a handle and front grip, and you solved the trigger problem with the trigger arm
