3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Knex Inverter lift
Knex Inverter lift
this is a very effective lift type
you can build as high as you want (if you have the pieces) and even use the chain lift too
and there are disadvantages
i don't know how to put a motor on it
lots of pieces
Step 1The Lifts
The Lifts
these are the lift you need to make
make as much as you need to make it at the desired height
You'll need (per lift);-
CONNECTORS RODS SPACERS
yellow 5 way 3 yellow 3 blue 12
green 4 way 3 blue 3 grey 6
blue 7 way (3D) 2 white 2
grey 1 way 6
25 comments
Sep 26, 2010. 11:38 PMFr-Pa-Co says:
Does this use a motor because if not it is completely worthless
Oct 14, 2010. 12:42 PMFr-Pa-Co says:
sorry i take it back im working on a way to add a motor if do i will make an instructable
Oct 3, 2010. 2:54 PMTornado96 says:
Maybe he didn't have a motor at the time. But you can make it with a motor. Just watch I_am_canadian.s Twister ball machine and look carefully at the mechanism. It isn't really that hard. :-)
Jun 4, 2010. 2:07 AMkutlulknex says:
this is best making it is the most possible lift to make the best is the big arm lift becuz it uses not much pieces this one use also not much but it is still too much so i,m just saying that this sure is the best one to make who's possible becuz u can get with one bag of k'nex no chains no bleu one slot connector NR. 2 BEST LIFT
Apr 19, 2009. 2:55 PMGobi says:
Just an observation from my own build that that the top yellow rod (as added in photo 3) does not need the two green connectors, nor the 4xBlue and 2xGrey spacers. This saves on parts and weight. I also found that the lever mechanism from the opposite lift often got hooked these extraneous green connectors and popped the ball out prematurely. Getting rid of these actually made my lift more reliable. Nice instructable BTW.
Oct 23, 2008. 10:08 AMpls says:
who ever made it, its awesome.
Oct 23, 2008. 1:35 PMpls says:
trainman said you didn't make it...
Dec 18, 2008. 4:06 AMTom Buckey says:
its on the knex website in the educational part for kids. its called newtons gravity law i think
Mar 6, 2009. 4:24 PMI_am_Canadian says:
Link please?
Mar 7, 2009. 10:33 AMTom Buckey says:
Mar 7, 2009. 11:01 AMI_am_Canadian says:
Ah, thank you.
Oct 24, 2008. 9:42 AMpls says:
oh, just wondering, cool none the less!
Oct 25, 2008. 6:22 PMThe KNex Weasel says:
This is cool, but I could swear that I saw this thing somewhere...probably the Book of 120+ ideas.
Oct 20, 2008. 4:17 PMDarth Trainman says:
You didn't make this. It came from k'nex in the k'nex book of ideas.
Oct 20, 2008. 1:28 PMknexfan9182 says:
heres 12 more will that do?
Oct 20, 2008. 11:51 AMI_am_Canadian says:
Thats my photo at the end!
Oct 20, 2008. 12:07 PMI_am_Canadian says:
Thats fine, I just found it funny.
Oct 20, 2008. 12:28 PMI_am_Canadian says:
it just is...
Nice!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:cubemaster53
