K'nex MP5
17,309
57
278
Published
Introduction: K'nex MP5
TGKT entry - This is my K'nex MP5 and one of my favourite real-life weapons of all time. It features a true trigger, 15+ round mag, full stock, and a rugged construction. The gun has yet to misfire (the bullet always leaves the barrel) and has fair range (30-45 ft).
In the instructable there is no assembly step as I assemble it as you build each main part. Follow sticky notes for the tricky spots before asking questions.
Pros...
-Small,compact, and sturdy
-True trigger
-Large magazine capacity
-Jam-free
-Good range
-Consistant accuracy
-Looks
Cons...
-Not good for long range shots
Step 1: Magazine and Barrel
Pic 1 - Build x2
Pic 2 - Add white rods onto ONE of the two panels made in pic 1
Pic 3 - Another view of pic 2
Pic 4 - Make all of these
Pic 5 - Slide them onto the corresponding rods
Pic 6 - Another view of pic 5
Pic 7 - Attach the red connector here
Pic 8 - Get the second panel ready
Pic 9 - All attached
Step 2: Trigger
Pic 1 - Trigger
Pic 2 - Different view
Pic 3 - Place it in the gun like so (leave it loosely in there for now)
Step 3: Outer Body
Pic 1 - Make this x2
Pic 2 - Attach to both sides
Pic 3 - Attached
Pic 4 - Trigger goes between these yellows
Step 4: Front Barrel
Pic 1 - Make this
Pic 2 - Attach to the front of the gun
Pic 3 - Different view
Pic 4 - yet another view
Step 5: Foregrip and Muzzle
The muzzle functions as a safety for the gun. It will block any bullet fire out. Simply remove when ready to fire.
Pic 1 - Completed Foregrip
Pic 4 - Yet another view
Pic 5 - Ready to attach
Pic 6 - Attached
Pic 7 - Other side attached
Pic 8 - Build the muzzle
Pic 9 - Attach it
Pic 10 - What you should have so far
Step 6: Handle and Trigger Guard
Pic 1 - Finished product
Pic 2 - Make everything seen here x1
Pic 3 - Attach
Pic 4 - Attach
Pic 5 - Ready to go onto gun
Pic 6 - Trigger guard is attached
Pic 7 - Line up the handle
Pic 8 - Attach
Pic 9 - What you've got so far
Step 7: Stock
A very sturdy, solid stock...
Pic 2 - Make this x2
Pic 3 - Make this x2
Pic 4 - Make this x1
Pic 5 - Make this x1
Pic 6 - Attach blue rods where shown
Pic 7 - Attach layer
Pic 8 - After layer
Pic 9 - After layer
Pic 10 - And this is the last layer
Pic 11 - read note
Pic 12 - read note
Pic 13 - Ready to attach bendy rods
Pic 14 - Attached
Pic 15 - Ready to attach the stock to the rest of the gun
Pic 16 - Attached
Step 8: VERY IMPORTANT
Important step... This keeps the ram from pointing down and hitting the magazine parts.
Pic 1 - Pull off this green connector
Pic 2 - As shown here
Pic 3 - As shown here put a green rod inside
Pic 4 - Inside and you're good
Pic 5 - Close it all up and you're great
Step 9: Mag Push, Firing Pin, Rubber Bands
Rubber band placement on the ram rod is key...
Pic 1 - Build and find these items
Pic 2 - This is another mag pushed that works a little better than the weird looking one
Pic 3 - Trigger rubber band (A little bit tighter than normal)
Pic 4 - Mag push goes in here
Pic 5 - Rubber band placement for the mag push
Pic 6 - Ram rod goes in here
Pic 7 - It's in with a little force
  • Pic 8 - Ram rod rubber band. It's on that blue rod I mentiond earlier. You could put it on other places but they have to be pulling from below the level of the ram rod, otherwise it will be levered down and hit the internals of the gun (Very low chance of happening). I advise using the spots provided in the picture and in the sticky notes to avoid problems. I will post a video on this. It's a very small problem (it only happened once) but this is just to avoid that.
Step 10: Loading
Pic 1 - Ammunition
Pic 2 - Load like so
To fire once loaded, pull back the ram untill the trigger clicks, then pull the trigger. Repeat untill ammunition is depleted then do pic 2 procedure and reapeat this procedure.
Pic 3 - Have fun and don't shoot anything unprepared to be shot at
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    278 Comments
    I have built all 5 of your guns, and when i get my youtube account in another year, i will post them on there. They are awesome guns!
    I don't think I will post them, but they are awesome guns. :)
    Could you please add a piece count for this K'nex model?
    i wish that i could build this gun but i dont have enough knex hinges.
    to compecated not to build but to load!!!!!
    all right. so i built it i cocked it filled up the mag pulled the trigger and it fell out of the barrel. woopie!a gun that shoots 4 inches!! the ball joint end keeps on beking off and the mag rod pushes the bullets in half way then it jams. . Either i suck crap with knex or this gun sucks.:(
    u probably suck crap with knex1 CAUSE THIS GUN IS AWESOME!
    what can i use instead of the hinges
    I had some problems with the trigger but fixed it and made it shoot gray rods
    i made the model perfectly and followed the instructions except the trigger don't work at all is there anouther one i can use in the model to make it work
    i built this gun and it shot amazingly. nice accuracy!
    I have a problem where the gun somehow shoots multple rounds per shot. Seriously, I loaded it up, cocked it, fired, four rounds came out...
    how is that a problem!!?? thats how real mp5ks shoot full auto!
    that is a defult I guess but if it still shootd strong and straight its makes it like almost full auto
    Huh? How does it being strong make it automatic?
    actually, kindof shotgun effect.
