Knex Revolver True Trigger
7,317
12
38
Posted
Introduction: Knex Revolver True Trigger
ok after i saw syprans idea for the taped up cylinder i couldnt let myself sleep without basing an instructable on it oh and by the way the pictures are crap because i couldnt find a real digital camera so i used my xbox live vision camera and i will probably post an instructable on how to set that up because well yes my internet friends it is a B1@h7 to set up if you dont take the easy way out
Step 1: Make the Cylinder
same as syprans only half the size 2 silver spacers rolled together make 8 of these put em on the the what sypran used and
Step 2: Make the Handle
simple and i guess comfortable
Step 3: Barrel Tip and Front Sight
just make this part
Step 4: Trigger
Step 5: Cylinder Platform
ok make sure the red connector faces down and must have those 2 spacers
Step 6: Inner Barrel
Step 7: Gather Last Pieces and Firing Pin
ok fixed this u do not need to modf the pieces gather these parts
Step 8: Assembly
ok attacth the cylinder to the cylinder holder ,that attaches to tip ,tp to top rail ,MAKE SURE U PLACE THE WHITE PIECE THERE, sides go on put trigger in MAKE SURE THAT BAR WITH CLIPS IS ON it keeps the trigger from falling outand the handle u saw the first pic i dont need to take another pic im lazy and hungry
Step 9: Loading FIring and Ammunition
first just find a good spot for a trigger rubber band and a firing pin rubber band 2nd get ammo take a preferably long rod or any rod that u find almost usless cut it into pieces as big as little green connectors i used a green rod flip 3rd pull back ram rod and open front barrel tip 4 either load te cylinder or replace it i have 2 cylinders so i can easily swap out the empty cylinder with a fresh one 5 close the barrel and shoot on pull back the ram rod change the barrel and pull the trigger i
I give alot of credit to sypran for his genius tape revolver cylinder idea
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    41 Comments
    about how many pieces
    whats wraped around the middle one?
    add some pics from difren angles
    nice gun, but... the ram never hits the yellow connector hole. It always hits above or below the hole, so it never fires. is there some way to fix it? if i can fix it i'll give you a 5 but right now youre at a 3
    I found a way to fix it! On the top of the handle, there is a white rod that sits just bellow the firing pin (See picture) ANd it clips on the second half cirlce piece. Clip it onto the top half circle, so its higher, and will just touch the firing pin. This pushes the pin up, thus keeping it away from the yellow connector hole in the barrel. :D
    yea im eventually going to redo this after i finish my next project its either going to im trying to build either an auto revolving rifle.a breach loading uzi , or a mp40 where you actually cock the gun by where the actual bolt would be
    should i build this or not someone make a reveiw!
    im actually going to update this soon soo i wouldnt
