3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Knife Sharpening Tricks
Step 9Don Montague Tests the Edge
His style of fingernail testing involves resting the edge on his nail to see if it slides off or catches.
7 comments
Oct 12, 2009. 8:35 AMgitm says:
I use the pad of my finger. I run my finger over the edge perpendicular to the length of the blade and without pressure. I also polish the blade, which I've found can make a fresh razor even sharper. There is a dramatic difference in the performance of gouges once they've been polished.
Jul 6, 2011. 7:35 AMmthomp1 says:
A fresh razor blade is never smooth or polished. Examine it under a strong magnifier, you will see what I mean.
Jan 1, 2010. 1:02 AMweaponscollector94 says:
how do you polish the edge?
Jul 6, 2011. 7:33 AMmthomp1 says:
You never need to polish the edge of the knife. Try cutting a tomato with a polished edge knife. It just won't cut it. There is a very tough thin layer on the skin of the tomato will prove it.
Apr 15, 2012. 9:45 PMthedriftcore says:
That really depends on the knife and its intended use, though in my experience a properly polished edge will cut almost anything, including tomatoes, like going through air. I've seen a lot of people who say that they polish the blades of their knives but actually change the angle of the blade right at the edge by squishing the blade down and that really messes with the knifes ability to cut. I do know that knives used for chopping stiff vegetables like carrots are better off with a polished edge, they chop just as good (if not better) and not having those scratches and micro-serrations reduces the chance of any water or other contaminants being left of the blade during storage. I've learned from experience that a polished blade will last longer than one that's not (simply in terms of storage time, the way in which the knife is used may change that).
Jan 17, 2011. 8:10 AMbinky82 says:
don't slide to cut, just see if it catches, just touch your nail and don't move it, sharp it should stop sliding and just catch 'on' the nail, not'in' the nail.
Jul 31, 2009. 1:47 AMTheBackyardInventer says:
I sharpened my swiss army knife till its like really sharp and it doesnt slide accross my nail or catch on my nail it doesnt really slide but it makes some nail powder
Jul 10, 2008. 5:41 PMAustralLord says:
I do it prependiculr to my thumbnail, is that ok?
Mar 18, 2009. 2:09 PMjkehrtzll says:
stupid....dont do that, take a piece a paper, hold it vertically and see if it cuts or rips the paper.......if it rips its dull. my buddy used his thumb nail and it went rite thru
Mar 18, 2009. 7:06 PMAustralLord says:
your friend must be malnutritioned
Jun 1, 2009. 7:38 PMjkehrtzll says:
okay....you just suck at sharpening knives. if it does NOT go through, then it isnt sharp enough lol
Jun 3, 2009. 3:01 PMAustralLord says:
Really, if you slice into your freaking nail you must be mental. I've got it now, the nail method requires you to put the edge perpendicular to the thumnail and then slide it off the nail- not along the edge (like -------), but parallel to it (|||||). If it doesn't stick to the nail, try sharpening it more because there's most likely a fault. Also the paper way is another good method, just to see how easily and cleanly it slices through, but I do always do at least both.
Jun 2, 2009. 5:06 AMgnose says:
okay..you must have very heavy knives there
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1250
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
