Sometimes the project is destroyed by the choice of switch.
A simple slide switch has none of the ominous effect of a Knife Switch. An evil switch for an evil project...
The switch needs to be labeled with laser etchings for maximum effect. I could not bring myself to deface it with a simple pen
Step 1: Materials required
I chose to use copper from old plumbing pipes and made a base from pine slats.
The screws used are brass 10-24 3/4 inch in length
Adambowker98 says: Dec 26, 2012. 7:35 PM
Wait, so is the copper tube sliced down the middle and then flattened out? Also, how do you cut the tube?
Random_Canadian (author) in reply to Adambowker98Dec 26, 2012. 8:58 PM
I cut the tube into 3 sections with a 24 tooth hack saw then flattened them as shown. I hope that this helps.
Xixfas says: Dec 11, 2012. 3:04 PM
isnt this a double-pole double-throw switch?
electfire says: Nov 15, 2011. 10:44 AM
Well done! I love knife switches, but sadly all that I have found are made of plastic...which doesn't look good in any steampunk/mad scientist type project.
Thanks to you posting this little how-to I might just make a few myself ... though I would only use them for low voltage, if need be triggering a relay to control higher voltage...
Random_Canadian (author) in reply to electfireNov 15, 2011. 5:12 PM
Thanks. I agree on the plastic bit. They do look terrible. I have added a smaller single knife switch to another project. Check out the Newton's cradle that I made.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
