Knife-makers Scribe
5,958
30
5
Posted
Introduction: Knife-makers Scribe
This is a step by step tutorial on how to make a knife makers scribe.
Step 1: Cutting Out the Body of the Scribe
First cut out the body of the scribe.
Step 2: Drilling Holes
Now that it's cut out drill the hole that the scribe holder will fit in.
Step 3: Drilling Holes
Now drill a hole for the screw that will keep the scribe holder from sliding up and down.
Step 4: Taping the Hole
Now tap the hole so that you can screw your bolt in so that the scribe holder can't move unless you loosen the bolt.
Step 5: Making the Scribe Holder
Now it's time to make the scribe holder.
Step 6: Drilling Holes
Now drill the hole that will hold the scribe and the hole that will hold the bolt that will keep the scribe in place.
Step 7: Taping the Scribe Holder
Now tap the hole on the bottom so you can put a bolt in to keep the scribe from moving. Put a set screw in the taped hole to keep the scribe from moving.
Step 8: Your Finished
Now your finished. Assemble it all and you have yourself a knife makers scribe.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    5 Comments
    Good job on explaining.
    @EmcySquare
    Forgive my ignorance: how do you use it?
    Place the blank of the knife on the flat part, run the edge to be side against the scribe. The scribe will leave a mark on the side of the blank. The mark needs to be in the middle of the thickness of the blade. That mark is used as a reference when grinding the bevel of the knife to be sure to have a streight edge. Sometimes the marks are two. It depends on the way the bevel is made and the hardening process.
    Thanks for the explanation.
    I made one very similar to this.
