Knit Touchpad
Knit Touchpad
This knit touchpad is possible due to the properties of the anti-static gloves, which are sold for handling sensitive electronic components. The glove is knit from stretchy fibers that also include resistive yarn (poorly conductive). Because of the way the fibers in knits travel from one side to the other, from top to bottom, the resistive yarn travels it doubles back on itself in a way that maintains the resistive connection even when the knit is cut (interrupted). The surface thus has a unique resistance at any point when measuring from at least three points. In this demonstration I chose to measure from all four corners.
The following updated video shows the data visualization from all four inputs. And calculates the position of the nail. As you can see it is not perfect, but you can also see that it does kind of work >>
This is the original video using the finger cap >>
Instead of attaching the Vdd or Vcc to the finger, one could also have it as a continuous conductive layer mounted underneath or above the knit, separated by perforated foam. Although this minimizes resolution to the number of perforations, it does free the user from the additional step having to wear the finger cap. But in this case I consciously wanted to test this method for a future project idea.
The knit does not need to be kept on a flat surface, I just did this for demonstration purposes and the next Instructable will show how this method can be used to turn the whole glove into a touchpad. And then hopefully the whole body, though the problem I have to solve here is how to isolate against the knit interfering with the measurable continuous resistance by touching back on itself.
Step 1Materials and Tools
Materials and Tools
MATERIALS:
- Conductive acrylonitrile stretch glove from http://www.all-spec.com
also see http://cnmat.berkeley.edu/resource/conductive_gloves
- Conductive copper tape with conductive adhesive by 3M http://www.3m.com/
also see http://cnmat.berkeley.edu/resource/conductive_tape_conductive_adhesive
- Ni/Cu Fabric Tape with conductive adhesive from LessEMF http://www.lessemf.com/fabric.html
also see http://cnmat.berkeley.edu/resource/ni_cu_fabric_tape
- Solderable perfboard with copper line pattern from All Electronics http://www.allelectronics.com/
- Male and female headers from Sparkfun http://www.sparkfun.com/
- Ribbon cable
- 4x20K resistors
- Thin, flexible wire
- Double-sided sticky tape
- Stretch conductive fabric from http://www.lessemf.com
also see http://cnmat.berkeley.edu/resource/stretch_conductive_fabric
- Fusible interfacing from local fabric store or
also see http://www.shoppellon.com
- Stretch fabric (jersey)
- Thread
- Cardboard
- Arduino and USB cable from Sparkfun http://www.sparkfun.com/
- Computer
- Arduino software free for download from http://www.arduino.cc/
- Processing software free for download from http://processing.org/
TOOLS:
- Sewing needle
- Scissors
- Wire clippers
- Wire strippers
- Soldering iron and solder
- Iron
30 comments
Jan 4, 2011. 1:56 PMBarsoomian says:
Hi, I was wondering if you remembered which corners were attached to which analog input port on the arduino?
Apr 18, 2010. 11:56 AMNoSuchNick says:
Hi,
i was wondering if this sensor has a varying resistance relative to the amount of pressure applied.
If it has, how do you correct for it? Do you first calculated the total pressure out of the 4 individual inputs, adjust the values and then calculate the position?
Bye,
NsN
Jul 5, 2009. 11:54 AMRadobot says:
This is a great project! But can you change the Conductive acrylonitrile stretch glove to something different (like some metal)? And can you use instead Arduino some circuit (what don't need program and have USB)?
Feb 22, 2009. 12:43 AMavibank911 says:
wow nice project!! can you use something besides Arduino , like usb or summin?
Jan 9, 2009. 8:46 PMchrischavez says:
I don't have any access to conductive fabrics or anything of the sort. would there be anything that i could make. i have access to a multitude of hardware stores and a walmart. maybe a conductive glue that is spread on a mesh. maybe just maybe a few items from the Internet.
Jan 11, 2009. 7:57 PMchrischavez says:
Thanks what I will try to do is make a drawing pad. maybe not that accurate but its something.
Nov 17, 2008. 7:19 PMAnarchistAsian says:
a little shaky, but great. is there any way to make it more accurate?
Nov 15, 2008. 11:10 AMleahbuechley says:
love this & all of your instructables plusea! so glad you're out there doing all of this cool stuff & sharing your projects!
Oct 1, 2008. 7:56 AMmacsimski says:
you can also use the antistatic bags Farnell uses to send you chips in. it's black plastic and also has a decent resistance. i've made one measuring 20x20cm to be used as a life midi interface, with a teaspoon as a controller.
Oct 5, 2008. 9:48 AMarchipeep says:
I would love to know a little more about your 20x20 midi interface! Perhaps you are thinking of posting your own instructable on this? ;) How well does it work, how accurate, etc.?
Oct 5, 2008. 9:34 AMmuffin1 says:
what if you had a carpet made out this stuff and you incorporated it in a video game, so you could walk around the room (with a peace of metal on your shoes) in the game. you could wear your suit thingie and it would be like a virtual reality game.
Oct 2, 2008. 7:57 PMsrhadaham says:
Any reason why you would use this over the touch pad on your laptop or is this just something to have fun playing around with?
Oct 2, 2008. 9:01 PMvanbo says:
Both, but it could also be used for a desktop.
Oct 3, 2008. 2:54 PMkylemcdonald says:
This is very cool. I think there might be a way to do this without a glove or nail. Do you have plans yet for using this? I'd like to see two contact improvisers wearing full-body suits made of this :)
Oct 3, 2008. 5:26 PMNoblevagrant says:
I heard about car makers putting sensors in the seats that affect the way an airbag deploys. if the actual seat fabric was made of this material it could really improve the accuracy. Also this would be nice as an interface for a carputer, imagine sewing a cap on your stickshift and be able to control the pc without removeing your hand from the shifter.
Oct 2, 2008. 5:00 PMGWJax says:
Very interesting project, I could see some use for this kid of thing in robotics. This is one project I'll have to play with. Thanks for info. Jax
Oct 1, 2008. 7:32 PMcowscankill says:
That is just awesome! I'm voting for it :D
Sep 29, 2008. 8:38 AMsrilyk says:
I think if you wrote in some jitter correction you could improve the accuracy. And considering the fact that you have 4 sample points, that should give you a reasonable margin of error, methinks. This is a really cool idea!
Sep 30, 2008. 11:48 AMsrilyk says:
That's a really cool idea... I can think of some really interesting possibilities for use with the disabled...
Sep 29, 2008. 10:28 PMsleepydog says:
What a wonderful way of figuring position! I love your project!
Rachel from Instructables and Soft Circuit fame has used bolt (that meshy stuff they make ballerina outfits from) as a separator between conductive fabrics in her switches. The "weave is open enough to allow easy contact under light pressure, but provides good separation between layers of fabric when it isn't being touched.
If you're looking for conductive fabric, check out http://lessemf.com/fabric.html it may be a little tin-foil-hat, but they have good prices and selection.
Sep 26, 2008. 10:02 AMPKM says:
Hmm.. how expensive is the stretchy fabric? Build one six feet across, project onto it and have a huge touchscreen without that pesky mucking about with webcams and IR :) You wouldn't even have to use a finger, one of those extending pointers like a radio aerial would work. Also, can you calibrate it to give absolute position? It seems like it would be a non-linear nightmare because of the multiple paths from the finger to the sensors...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
332
Author:Plusea
