Introduction: Knitted Spiral Hat
Fall is here! Time for hats!
I love hats and with the change of weather comes an excuse to make more hats. Here is the one of my patterns that I have came up with. This is the second iteration of this pattern that you can make with basic knowledge of knitting
This is a really simple and fun pattern great for guys or girls. At the end of this instructable I will put the full pattern in a downloadable PDF for any of you who want to make it.
Step 1: Materail
needed skills:
cast on
knitting in the round with double pointed needles,
knit stitch
pearl stitch
knit decrease
pearl decrease.
needed materials:
70 grams of worsted weight yarn
(5) 3.75mm, 7 in double pointed needles
scissors
3.75mm or 3.50mm crochet hook
yarn needle
stitch markers
Step 2: Cast on
Cast on 83 stitches to four double pointed needles.
21 on the first needle, 21 on the second needle, 21 on the third needle, and 20 on the fourth needle.
Cut off the excess tail that is left from casting on and you're ready to knit!
Step 3: Knit the Sides of the Hat
Simply put this hat is knitted by changing stitches every 6 stitches. Because there are 83 stitches in this hat the last set of stitches at the end of round one has 5 purl stitches. The sixth purl stitch for this stripe is the first stitch in round two. This shifts everything over by one with every round. Every 12 rounds the rounds repeat. So round 13,26 and 39 are repeats of round 1.
k = knit, p = purl
round 1: k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p5.
round 2: p1, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p4.
round 3: p2, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p3.
round 4: p3, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p2.
round 5: p4, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p1.
round 6: p5, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6.
round 7: p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k5.
round 8: k1, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k4.
round 9: k2, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k3.
round 10: k3, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k2.
round 11: k4, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6,k1.
round 12: k5, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6, k6, p6.
Put a stitch marker in between the last stitch of the 12th round and the first stitch of the 13th round.
Repeat this four times.
Step 4: Decrease
Simply put you just continue the same pattern of stitch changes and decrease in those spirals
k=knit, kd= knit decrease, p=purl, pd=purl decrease
decrease round 1: k2, kd, k2, p6, k6, p2, pd, p2, k6, p6, k2, kd, k2, p6, k6, p2, pd, p2, k6, p6, k2, kd, k2, p5
decrease round 2: p1, k5, p6, k6, p5, k6, p6, k5, p6, k6, p5, k6, p6, k5, p4.
decrease round 3: p2, k5, p2, pd, p2, k6, p5, k2, kd, k2, p6, k5, p2, pd, p2, k6, p5, k2, kd, k2, p6, k5, p3.
decrease round 4: p3, k5, p5, k6, p5, k5, p6, k5, p5, k6, p5, k5,p6, k5, p2.
decrease round 5: pd, p2, k5, p5, k2, kd, k2, p5, k5, p2, pd, p2, k5, p5, k2, kd, k2, p5, k5, p2, pd, p2, k5, p1.
decrease round 6: p4, k5, p5, k5,p5, k5, p5, k5, p5, k5, p5, k5,p5, k5.
decrease round 7: p2, pd, p1, k5, p2, pd, p1, k5, p2, pd, p1, k5, p2, pd, p1, k5, p2, pd, p1, k5, p2, pd, p1, k5, p2, pd, p1, k4.
decrease round 8: k1, p4, k5, p4, k5, p4, k5, p4, k5, p4, k5, p4, k5, p4, k3.
decrease round 9: kd, p4, k2, kd, k1, p4, k2, kd, k1, p4, k2, kd, k1, p4, k2, kd, k1, p4, k2, kd, k1, p4 k2, kd, k1, p4, k2,
decrease round 10: k2, p4, k4, p4, k4, p4, k4, p4, k4, p4, k4, p4, k4, p4, k1.
decrease round 11: k3, pd, p2, k4, pd, p2, k4, pd, p2, k4, p2, pd, k4, p2, pd, k4, pd, p2, k4, pd, p2,
decrease round 12: k4, p3, k4, p3, k4, p3, k4, p3, k4, p3, k4, p3, k4, p2.
decrease round 13: p1, k4, p3, k4, p3, k4, p3, k4, p3, k4, p3, k4, p3, k4, p1.
decrease round 14: p2, k1, kd, k1, p3, k1, kd, k1, p3, k1, kd, k1, p3, k1, kd, k1, p3, k1, kd, k1, p3 k1, kd, k1,p3, k1, kd, k1
decrease round 15: pd, p1, k3, pd, p1, k3, pd, p1, k3, pd, p1,k3, pd, p1, k3, pd, p1, k3, pd, p1, k3.
decrease round 16: k1, p2, k3, p2, k3, p2, k3, p2, k3, p2, k3, p2, k3, p2, k1.
decease round 17: kd, p2, k1, kd, p2, k1, kd, p2, k1, kd, p2, k1, kd, p2, k1, kd, p2, k1, kd, p2,
decrease round 18: kd, pd, kd, pd, kd, pd, kd, pd, kd, pd, kd, pd, kd, p1
decrease round 19: kd, pd, kd, pd, kd, pd, kd
Step 5: Finish the Hat Off
Slip the seven remaining stitches on to the crochet hook. Cut the yarn off about 12 inches off from the hat. Pull the end through the seven loops and then to the inside of the hat. Tie it off, weave the end in and cut off the excess.
if you enjoyed this instructable, thought it was written, liked the project, like the add on or for any other reason please vote for in in the fall in to yarn contest
