Knitting Lesson One: Casting On
925
17
Posted in CraftKnitting-and-crocheting
Introduction: Knitting Lesson One: Casting On
Hello today i will show you two methods of casting on.
Casting on is sometimes referred to as CO in patterns.
If you don't understand the steps refer to the pictures
You will need:
A pair of needles
A ball of wool
Step 1: The First Method
The first method i will show you is called the Knit cast on.
Step one: tie a slip knot on one of the needles
Step two: insert the right needle into the knot
Step three: get the wool and put it round the needle which you inserted into the knot
Step four: with the right needle slide it down and over the wool which was wrapped round the needle
Step five: put the stitch that is on the right hand needle onto the left needle
Step six: copy step 2-5 until you have the right amount of stitches
Step 2: The Second Method
The second method i will show you is called the cable cast on, I find this cast on is more neat, tidy and has less holes than the knit cast on.
Step two: insert the right needle into the slip knot
Step three: get the wool and put it round the needle that you inserted into the slip knot
Step four: slide the right needle down and over the wool
Step five: put the stitch that is on the right needle onto the left needle
Step six: put the right needle in between the two stitches
Step seven: put the wool round the needle in between the two stitches
Step eight: slide the needle back and over the wool
Step nine: put the stitch that is on the right needle onto the left needle
Step ten: repeat step 6-9 until you have the right amount of stitches
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    Nice! Thanks for sharing this knitting lesson!
