Introduction: Knitting Needle Holder
This is a great holder developed for my handmade knitting needles or any knitting needles you may have. Its great as a gift to give your needles or to use while traveling with your knitting, keep extra needles you may need in this holder while on the go. http://www.etsy.com/view_listing.php?listing_id=6288389
Materials:
*scrap fabric at least 14 inches x 16.5 inches if using one fabric, or if using separate lining fabric 7 inches x 16.5 inches of each 2 fabrics
*fusible interfacing
*iron
*sewing machine and matching thread
*one button of your choice
*elastic tie
*pins
*ruler
*removable fabric marker
Materials:
*iron
*elastic tie
*pins
*ruler
Step 1: Cut Your Fabric
Cut out you fabric, 3.5 inches x 16.5 inches, and 3.5 inches x 10 inches of both fabrics, four pieces total, this gives a seam allowance of 0.5 inch on each side, also cut 2 pieces of iron on interfacing, one of each size
Attach your interfacing (I use iron on) to the back of your main fabric pieces, not the lining pieces
Step 2: Using 2 Smaller Pieces
Take your 2 smaller pieces and pin them RS together
Step 3: Sew One Side
Sew one short side of these pieces that are pinned together, close to the edge
Step 4: Press Seam and Turn RS Out
press back side of seam open and then flip so fabrics are right side out
Step 5: Put This Piece Together With Larger Lining Piece
Lay your newly sewn piece on top of the long lining piece, right side of lining pieces facing each other, (pink) main fabric on top and sewn end towards the middle ( thie picture shows it towards the left)
Step 6: Pin and Measure
With these pieces lined up, pin together and then measure the mid point, to where your going to sew your line that creates the left and right pockets, mark this line to sew whith chalk or fabric pen that can easily be removed
Step 7: Sew the Line for the Pockets
Sew the line you just drew, up the middle, stopping at the top of the pocket (I conveniently have stripes on my fabric so I didnt need to draw a line)
this step will also connect the longer lining piece to your pocket
Step 8: Attach Your Button
At this point I add the button that the elastic will hook to, or other closure you may want to use (Velcro, snaps)
by using an elastic closure it helps make your closure easily adjustable, I usually place a button right down the middle line about 3.5 -4.0 inches from the top of the pocket, lower for a longer piece of elastic, higher for a shorter piece of elastic, sew this button on through all layers
Step 9: Sandwich All Pieces Together
you should now have your pocket piece which has been sewn together, and your remaining larger main fabric piece.
Lay your pocket piece and your remaining fabric with RS together, Wrong sides out
Step 10: Pin Elastic in Place
Pull the elastic hair tie out of your hair like I did and pin it to the top of the holder, not the pocket end, having most of the tie inside the pieces and just the tip of it outside so you can see where the center is, the part that is pinned inside is the length of the elastic that will hook to your button
Step 11: Sew All Pieces Together
Next your going to sew 3 sides of the holder together, both long ends and the end with your elastic leaving the other short end open (the bottom of the pocket stays open for turning later)
you may want to backstitch over the part with the elastic piece to secure it, since it will be stretched out when attached to the button
Step 12: Trim and Turn
Trim your sides and corners and turn right side out through your opening at the bottom, poking out your corners with a spare knitting needle
Step 13: Topstitch Opening Closed
Fold in seam on open end, press with iron and top stitch closed
Step 14: Enjoy
Enjoy your new holder or give as a gift with your homemade knitting needles and stitch markers
