Man has long wrestled with Time. Also, with knocking on things and not getting the time of day. We propose a knocking platform through which these fundamental needs are met. This is illustrated with the Knock Block KUI and accompanying Clock Knock Block application. The Knock Block possesses realistic knocking action with a human-like variation in frequency and amplitude of knocks.
Just knock on the Knock Block, or even the surface on which it's resting, and it will knock back the time to you. First it will knock the number of hours, and then the quarter hours.
If you knock several times, the Mock Knock Block application will take over, and repeat back your knocking pattern.
Video: http://www.vimeo.com/6713094
Remove these ads by
Signing UpStep 1Inside the Knock Block
Parts list:
- any Arduino can handle this
- a TIP31C high current transistor for the switch
- the exotically named Jameco 191172-001 solenoid, prized for its low price ($3!) and current
- a Measurement Specialties DT-series piezo film element (pretty sure that's the model)
- a 1M ohm resistor (your mileage may vary)
- 9V battery
- block case of your choice
I am having a big problem using a piezo sensor in a project I am working on. I just cant get it to sense anything practically. If I hold it and flick it I get a big spike of course, but once I tape it to a surface I can knock all I want and I get almost nothing, maybe 5-6 out of the 1023 of the analog sensing range from the arduino.
Can you explain how you're attaching it a little better. I just dont know what I'm doing wrong. Thanks for your help.
Keep in mind that the Arduino's sampling rate may be too low to capture the high-frequency waveform produced by knocking a piezo. Our rich mahogany case probably helped deepen it. You could try smoothing out the sharp waves with a capacitor, if it is just a sampling-rate issue.
The capacitor sounds interesting. What rating would you recommend and how would you recommend I connect it?
Thanks!
(PLEASE don't call it a schlock mock knock block ;¬)
How long does the battery last in it? I can't imagine it would drain them too quickly. Also, would it be possible make a plug on it to plug it into say a USB port for charging only?
