3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Kodak "Cattle Prod"
Kodak \"Cattle Prod\"
I previously had a slideshow showing my Kodak "Cattle Prod". And, well, here are the instructions on how to make your very own Kodak Cattle Prod.
PLEASE!!! Do not shock people with this device without consent. You never know who has a pacemaker.
I am trying out a new method to make my instructables "less confusing". I am listing every little step as a separate step, instead of combining them all. Please let me know how you like this method, or if I should use my old method.
Don't forget to rate it if you like it, and visit my other achievements.
And If you have trouble understanding the camera modification, or for reference, refer to this tazer instructable.
Step 1What You Need
What You Need
You need the following:
- Kodak Camera (do not use black and white)
- PVC Tube, whatever length and width you choose (I used 2")
- Right Angle PVC Thing, I don't really know the name, but it is pictured below
- Wire
- Soldering Iron
- Solder
- Bump Switch, which I stole from a mouse
- Cardboard
- Leatherman (or scissors)
- Pen
- Hot Glue Gun w/Glue (not pictured)
- Altoid Tin (or project box)
- Duct Tape (if you are using a tin)
39 comments
Feb 6, 2011. 1:55 PMomaramr says:
does this work without a battery or what because i saw other tasers not cattle prods that work with a battery.
but it is really good, nice one
Nov 7, 2010. 8:39 PMlawn_mower_man says:
Great Instrucable, thinking about making it into some kind of can lol :P. Question tho, What gauge of wire did you use?
Jun 29, 2010. 8:23 PMLetsExplodeSomething says:
would a capacitor from a old computer PSU work? it would give a slightly larger shock lol
Mar 10, 2010. 8:18 PMIsland-itis says:
I'm looking for something like this as a dog-zapper, to deter the many aggressive dogs roaming the streets, when my wife walks.  Just want a short tube that can be switched on and off easily on the handle while walking.  Don't want anything that looks like a gun : ))  Would this do the job or is there another design more suitable?
Jun 15, 2010. 10:41 PMpie R []ed says:
The circuit should work fine for a dog deterrent. Just don't use the tube handle. The Altoids tin houses all the crucial pieces. All you need to do is to add ducked tape on the outside and move the long wires there. I would also recommend not using a bump switch. It is fine for the cattle prod, but could be pressed accidentally in a bag or pocket. Try using a toggle switch. Also don't assume that just because it sparked once the capacitor is fully discharged. Touch it to a metal object a couple of times to make sure. These things hurt quite a bit if you get shocked so be careful!
Jun 13, 2010. 5:22 PMpyroal says:
if i make one i would wire three capacitors and test it to see how mush shock its packing.
Feb 20, 2010. 4:11 PMIridium7 says:
 I have that same soldering Iron! btw if you make the tube long enough you can have quite a bit of room to run.
Jul 9, 2009. 5:06 PMbdblock94 says:
he ow
May 16, 2009. 9:45 AMJohnMichael says:
This is a good start. I have a few thoughts, if you decide to make another... Step 1: The "right angle PVC thing" is a 90' elbow. I believe 45' elbows are also available. Step 4: Why not paint the tin and PVC all the same color? It might give it a cleaner look. Step 7: What is the purpose of lengthening the connections to the capacitor? Step 11: Why connect the wires to the capacitor connections rather than the flash connections? It might also help to remove the flash as it may draw some of the charge away from your wires to the other end. If you added a switch connected to the trigger for the flash then you would have more control over when it discharges. Though if you want it to simply discharge on contact then the way you have it is good. Step 17: You might get a cleaner look if you ran the wires to the switch inside the PVC, though that might make it more difficult to put together. You might also consider moving the light that indicates when it is charged somewhere you can see it. Step 18 - 20: Have you considered using a PVC end cap and PVC cement rather than cardboard and hot-glue? I have been considering building something similar. Your instructable has helped me figure out some of the details. Thanks for sharing.
Dec 16, 2007. 2:35 PMmbuc91 says:
I went to the WalMart photo dev desk and asked for some, saying it was for a school project. I walked out with two garbage bags full of used cameras, all with flash circuits.
Apr 9, 2009. 4:33 PMBarrettkg says:
everytime i go they always ask why and just give me 5-10 : ( i need to go to your WalMart
Feb 14, 2009. 5:07 PMjunits15 says:
DUDE!!!!!!!!!!!!!!!!!! I WISH I HAD KNOWN THAT BEFORE I SPENT 20 BUCKS ON STUF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mar 10, 2008. 5:47 PMGjdj3 says:
Haha. I love "school projects." You can get the coolest stuff with those 2 words.
Jan 24, 2010. 7:46 AMstephenniall says:
i love  them too now to go to the chemical store and try and use that excuse
Jan 25, 2009. 7:00 PMpietro pedro pete says:
amen to that
Jan 25, 2008. 1:47 PMTrace II says:
I knew they were easy to get, but not that easy
Mar 10, 2009. 11:02 AMDerin says:
Was your old username EthanGibson?Because that's the name in the notes.
Jan 27, 2009. 9:35 PMPugFreek says:
I got a whole bunch of McDonalds stuff with those 2 words, school project
Dec 17, 2007. 3:06 PMGorillazMiko says:
i have the same battery powered soldering iron as you!
Nov 21, 2008. 7:43 PMJr Hacking kid says:
go to walmart and ask them for the cameras thats bin processed
Jun 6, 2008. 7:49 PMdarth acexxacer says:
you have an owie lol
Sep 25, 2008. 7:04 AMcorey_caffeine says:
It turned me into a newt
Jun 8, 2008. 7:51 PMcaeleybug1 says:
nice yet, painful
Jun 7, 2008. 8:43 PMskunkbait says:
Dude I disgovered the "shocking" nature of those cameras the hard way. (All I wanted was the battery!) I suspected you could make a stun gun out of them, and you've done a great job of showing just how to do it.
Feb 21, 2008. 12:10 PMsabre says:
you should run a couple of charged wires up and down the outsides of your pvc pipe "barrel".
Jan 13, 2008. 4:35 AMdrummonkey92 says:
nice instructable, iv just finished a telescopic tazer thats realy simple, im gona post it now
Dec 18, 2007. 1:28 PMcowscankill says:
great thing to use with my instructable
Dec 20, 2007. 1:31 PMcowscankill says:
thanks for adding a link to my instructable!
Dec 18, 2007. 9:03 AMJake-off says:
HAHA, well hot damn, you final got an Instructable up for this. great job
Dec 17, 2007. 3:29 PMreedzilla says:
nicely done...I like this method you used for making the instructable; it's a bit easier to follow step by step how long does the camera usually last? quite a few shocks?
Dec 15, 2007. 7:10 PMWhaleman says:
Yay! Now all I need to do is get myself a disposable camera!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
93
Author:Doctor What
