3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Kombucha Brewing Instructions
Brewing kombucha tea, or Manchurian tea, is an easy process which only requires a minimal amount of time, some common kitchen utensils, and some basic knowledge about cultures and good hygiene. If you look after your mushroom culture and care for it properly it should last you a lifetime!
Brewing the kombucha tea is a simple process of boiling water and sugar solution, adding and steeping the green or black tea. Then allowing this mixture to cool to room temperature before adding the kombucha cultures. Once you have tried it a few times it will be a very easy process to remember. So Let's Get Started Brewing Your First Batch Of Kombucha Tea!
Step 1Getting Started...
Getting Started...
What you'll need to get started brewing kombucha tea...
There will be a few items that you will need to gather before starting:
- A fresh kombucha culture starter, organic if possible. You can search the web for a starter or go here for a good organic source http://store.anahatabalance.com
- A pot to heat the water/sugar solution. This can be metal for this step.
- Distilled water (the best choice) or well water, never city water
- Cane sugar or other natural sugar, we suggest organic cane sugar
- Tea (Camellia Sinensis) - This may be green,white, or black tea, or a mixture thereof, we again suggest organic tea. Fruit tea and herbal tea will not work asthey do not provide the proper nutrients for the growing cultures. However, feelfree to add these to your finished product for added health benefits.
- A glass container for fermenting the tea solution (an old gallon pickle jar works great!) Here some people use plastic, if you do, make sure it is food grade plastic with a #2 symbol on the bottom. We always use glass container for safety reasons. Never use lead crystal, ceramic, or metal containers to ferment kombucha cultures.
- Clean cheese cloth (you can double this up if it seems to thin) or clean T-shirt, cut to size.
34 comments
Jan 30, 2012. 1:36 AMbrucedenney says:
If you want to get a kombucha baby, try the international kombucha exchange..
http://www.kombu.de/gebe-eng.htm
Jul 29, 2011. 6:44 PMmatt_and_nick says:
what is kombucha? i have no clue, i see it all the time on here, but i nevfer really can tell what it is.
Aug 6, 2010. 3:25 PMTahoeGal says:
Why do you say maple syrup or agave never be used? I am curious if you have experienced something or have more knowledge about it than what I have learned. It is my understanding that as long as there is sucrose available it will feed the culture. A (well educated-IMO) TCM doc and scoby supplier says you can also use raw (not treated) honey. Each kind of sweetner adds it's own flavor element and will change the percentages of various elements, but will still produce a viable scoby. He also mentions combining various types if you are using something other than regular sugar for best results as the yeast portion and the bacteria portion reproduce differently and are affected by the sugar(s) used. These sugars also affect the Acetic and Gluconic acid percentages as well as the taste. For a lot of really great info and research facts take a look at this guys page! http://www.happyherbalist.com/sugar.htm
I just wanted more info from you if you had any on using other sugars. PS Thank you for the pictures and the brewing info btw!
Feb 16, 2008. 1:19 PMxrobevansx says:
can you equate the taste to some other flavors someone may be able to grasp? Is it like a regular tea? I assume it is alcoholic since you are basically fermenting sugars, right? I am just wondering how it tastes.
May 25, 2010. 7:39 PMTracysnbb says:
I have bought Synergys' Drinks w Kombucha in it and really liked it (a lot!)b,but it's pretty expensive to purchase on a regular or semi-regular basis. $ 3.99 on sale at Rainbow acres in CA.
This is why I'm now trying to make it.  If you want to try it w/o a lot of expense, I recommend trying one of the brands of these drinks you can purchase at a Health Food Store 1st, to try to get an idea of what it will tast like. only if your just drinking it staight, I would imagine it will be much stronger.
Oct 28, 2008. 2:45 PMsonaps says:
Depending on the type of tea, ratio of the batch to mother size, and the time you allow it to firment it can have anything from a taste like Hard Cider to something like condensed Lime juice in my experiences. Also, adding in extra amounts of sugars at varying times (not advised) can make it much sweeter, like a soft-drink.
Feb 17, 2008. 12:08 PMSWV1787 says:
to put IvanJM's answer more simply it does not have much alcohol if any in it since air is allowed to enter the ferment continually and the flavor is reminiscent of hard cider if you bottle and chill it overnight before drinking.
Feb 16, 2008. 11:39 PMIvanJM says:
Just to get it out of the way, no it is not alcoholic. Here's a mini lesson in brewing. When you ferment grape juice with yeast you get wine (yeast = alcohol). If your not properly cleaning the equipment you may accidentally allow a bacteria to enter your wine and you will then have vinegar (bacteria = acid). The bacteria actually metabolize the alcohol. From the yeast you get some very useful vitamins, and from the bacteria a number of different acids that your body can use, but that we don't normally find in measurable amounts in our food.
Different cultures have fermented lots of different stuff. Every once in a while some one got sloppy and contaminated his alcohol ferments. If the result was still palatable they kept doing it.
If you leave it sit for too long (like a month or more) the yeast will eat all sugar and convert it to alcohol, and the bacteria will convert the alcohol to vinegar. The result will be very similar to Apple Cider vinegar. Most brewers do not want their drink that strong, and mostly ferment for 7-14 days. This results in a drink somewhat like Apple Cider but with a tart edge to it (like drinking Cider with a vitamin C in your mouth). If you have ever made wine, or tasted a very young wine you will have noticed that the taste of it isn't as well rounded as a bottle that is a year or more old. This is because the tannins are still very much intact. Some brewers will bottle their Kombucha (sealed to slow down the yeast and bacteria growth) and let it sit for a number of days. The result is much more well rounded in flavour.
Other kinds of real tea can be used besides common black teas. The resulting Kombucha will have the qualities of the tea you start with. Black Tea Kombucha is somewhat astringent, but with a bolder flavour. Oolong Kombucha is less astringent and retains the sweet ginseng-like aftertaste. Green Kombucha has a more grassy, flowery flavour. Some describe the differences between black and green as being like comparing wine to beer.
Feb 19, 2008. 4:13 AMQuinns says:
Nice instructable, what I would like to know is how the culture is started in the first place, the only recipes i have read call for a SCOBY from one of your kombucha brewing buddies, I don't actually have any kombucha brewing buddies, and I am aware that many people will send one to you for the cost of shipping. But how do you make one from scratch? or have we been using cultures grown off other cultures since the beginning? Cheers, good work
May 25, 2010. 7:32 PMTracysnbb says:
You can make your 1st starter with 2-4 Tablespoons of Organic distilled white vinegar and pouring it in when a starter or Scoby is called for.  I learned this from the prev. web site I just visited to learn about making my own Kombucha Beverages.
I've looked at plenty, and booked marked them, but when I try to get back to this page,I have to go thru too many steps.
Sep 17, 2009. 4:28 AMtechnosapien says:
I've read where you can go to a health-food store or international market and buy unpasteruized kombucha, it should have some of the culture in it, enough to make a new mother if you want. Check: http://www.instructables.com/id/Making_your_own_Kombucha_mother/
May 23, 2011. 2:55 PMRobyntheslug says:
The same way the first kombucha culture started, captured from the wild. There are tons of wild yeasts and bacteria, and the right nutrient combined with a little luck can indeed net you an accidental SCOBY. Still, I'd recommend getting a mother or creating one from raw kombucha.
Mar 23, 2010. 7:17 PMladylissa says:
Where did you buy that culture?
May 30, 2009. 11:40 AMWard_Nox says:
voted the #7 grossest drink on cracked.com
http://www.cracked.com/article_17174_p2.html
May 9, 2009. 7:15 PMmcadwell says:
I got my scoby on freecycling.org (Thank you Robin!) so have been brewing kombucha since February. Yum! I found out that, in the winter time, my attic stairs are the perfect place to brew this stuff - it doesn't get bothered and it's cool and dark. Now if only I could find another gallon glass jar so I could make more at one time.
Aug 31, 2008. 3:53 PMshes_a_rainbow says:
I have some tea that is a mixture of black and yerba mate- would that work as well?
Sep 4, 2008. 12:56 AMtaraist says:
Awesome idea! Thanks!
Jul 13, 2008. 1:12 AMALWAYS. says:
Has anyone made it with juice like GT's? I would really like to know, because although they are having a special on kombucha 2 for 5, I'd much rather make my own.
Sep 3, 2008. 10:00 AMAoiKaze says:
I used some plain origunal gt's kombucha and put it in a jar with a cloth cover. Within a few days it formed a skin then made a kinda mini culture. (I've been observing it mostly though I've read you can use the culture to make kombucha. I FINALY found a sourse to get a real scoby from and have been using that.
Jun 29, 2008. 8:40 PMharleyxx says:
I'm on my 6th batch of Kombucha, and love this stuff. The health food stores sell it for about $4.00 a bottle, so I have bottled mine up and have several weeks supply. I didn't like the green tea, it seemed to lack flavor so i switched to black tea. It's much better in my opinion. I drink a couple bottles of my own brew everyday for lunch instead of going to McDonalds and have lost about 15 lbs. For my last batch I substituted Orange Blossom honey for the sugar and it is by far the best tasting batch so far. I had to throw out my old mothers since none of my friends were willing to try it. Here are a few pics of my brew:
Mar 29, 2008. 1:47 PMdiscontinuuity says:
So I have most of the materials ready to make my own kombucha, but I have a couple questions. First, is it possible to use beer bottles to bottle this stuff? I drink more beer than I do anything that comes in PET bottles. How long would I let it pressurize before putting it into the fridge? Second, can I use other sweeteners such as honey? Third, what would happen if I add baker's or brewer's yeast to the kombucha culture? Would one kill off the other? Would it make more alcohol?
Jun 10, 2008. 6:59 AMclarextina says:
i've heard that the bottled kombucha is very likely to explode. maybe more so than home brew beer. sounds kinda dangerous. i'm staying away from glass, personally.
Apr 17, 2008. 2:51 PMdiscontinuuity says:
Apparently, you can do a second fermentation in anaerobic conditions to make more alcohol:
http://www.happyherbalist.com/second%20stage%20fermentation.htm
Apr 21, 2008. 6:41 AMharleyxx says:
I finally got two mothers from Kombucha.com since no one was willing to share theirs. I started two batches, one with green tea, the other with black tea. After three days, the mother in the green tea sank to the bottom and it looks like the beginnings of a new mother are forming on the top..I hope its not mold. The motherin the black tea is still floating on the top. I have several empty kombucha bottles I am going to use when it is ready to bottle.
Apr 7, 2008. 8:47 AMharleyxx says:
Anyone in the Daytona Beach area willing to donate a mother for my first batch?
Feb 16, 2008. 1:07 PMGorillazMiko says:
Nice Instructable. It has good detail, and the pictures are nice too! Nice Instructable once again!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:anahatabalance
