3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Kombucha Brewing Instructions
Step 6Culturing the Tea Beverage...
The last step is to allow the inoculated tea solution to set in a warm place, out of direct light and undistributed. It will take 2 to 3 days to see the start of the formation of the new kombucha
culture. Which appears as a translucent jelly-type layer forming on the surface of the tea solution.
At 5 to 14 days the fermentation process is complete. This time will very depending on the environment & temperature, the mushroom culture likes the temperature to be between 75 and 85
degrees. Having the incorrect temperature, especially in winter time, seems to be where most people go wrong.
After the 5 to 10 days, you'll want to start checking if the tea is ready to drink. You may buy pH strips for testing acid content, however, this is not necessary. The easiest way to tell if your tea is ready is by smell and taste. You may use a straw to pull a small sample from the side of the jar, trying not to disturb the new culture growing on top of the tea solution.
After brewing a few batches of kombucha tea you'll know when your tea is finished and ready to drink! If using pH test strips, the pH reading should be between 2.5 - 3.2. This range tells us that the organic acids, pro-biotics, and nutritional benefits have been fully produced and that the culturing process is complete.
The finished tea should have a slight vinegar smell, not to strong, and have carbonation. If your tea still smells sweet and/or is flat, then most likely it needs to set a few more days. After 5 to 10 days, the taste should be fizzy, semi-sweet, and similar to apple cider in appearance. Allowing it to brew longer (8-14 days) produces a sharper vinegar taste and contains a higher amount of beneficial medicinal properties.
Now that the brewing cycle is complete, you can simply bottle any extra tea into clean glass containers or jugs.
To start a new batch, just follow the above instructions remembering to save some starter tea for the next batch. If you have more questions you may go to this website for photos, FAQ, and a lot of information on kombucha - http://www.organic-kombucha.com
Happy Culturing !
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:anahatabalance
