Introduction: Krylon Dual Paint + Frame = Necklace Display
I've been wanting to make a necklace holder for a while. Mine just get tangled collect on my sunglass shelf. And honestly, I can't remember half of what I own, which means I never wear them.
You can see the original post at http://lifecraftsandwhatever.blogspot.com/2011/07/krylon-dual-paint-frame-necklace.html
Step 1: What I Started With, a Basic Frame
This is what I started with. Nothing fancy, just a good sized frame. I really wanted more details on the frame, but for $2, I wasn't going to complain.
Step 2: Supplies
I then hit up Lowe's, and picked up some trim for $5 (I already had the Gorilla wood glue at home). Just a suggestion. Measure before you cut to see if you have enough wood. I cut first, then realized I only had enough wood to go on top and bottom, instead of all the way around like I planned. So one of my wood pieces has a seam on it. Oops.
Step 3:
I attached the trim and let it dry over night. Then I laid it out on my super fancy painting station (otherwise known as a bar stool with a trash bag wrapped around it)
Step 4: The Spray Paint
Then I got out my spray paint that Krylon was nice enough to let me try. I usually use Kilz primer (when I remember to primer) so I was really excited to try this out. I'm all about saving steps where I can. It went on super easily, wasn't thick and gritty like Kilz can be. I did three coats, it had really great coverage.
Step 5: The Holes
Next I marked and drilled my holes. Most I spaced out every 1.5 inches, some I did at 2 inches (for those chunkier necklaces). I drilled the holes with my dremel. They're not pretty, it took me a few holes to realize that I needed to put the drill bit on my mark, and then turn it on. If I already had it turned on, it would just skitter and dance all over the place. Then I screwed the hooks in the holes (I picked up a pack of I think 50 hooks at Walmart for $3). My holes were a bit too big for the hook screw part, but it wasn't anything a drop of E6000 didn't fix. I admit, I need more patience with my crafts, and should have waited for the cordless drill to charge so I could use the correct size drill bit, but I make it work.
Step 6: Antiquing Glaze
I picked up some antiquing glaze at Lowe's for $8 (they don't sell it at Home Depot, FYI). I've been dying to try this stuff out, and knew it would give my necklace display some depth and dimension.
Step 7: Putting on the Glaze
It's super easy to use, just apply it with a stiff bristle brush, it has about a 15 minute window that you can mess with it. Make sure you get into all the nooks and crannies.
Step 8: Finishing Up the Glaze
Then take a paper towel and wipe it off. You can take off a lot or a little, it's up to you.
Step 9: Finished!
And then it's time to hang it up!
2nd Annual Krylon Summer Contest
