Step 3Glue Magnets to Tiles
If you're using the adhesive dots, all I did was peel off the backing on every other dot and attach magnets to the adhesive. Then I pulled the magnets up and attached them to tiles. If you make sure that the same pole is always pointing up, your magnets won't attract to each other, and you can do these in batches. It goes a lot quicker than doing one at a time.
If you're using glue, make sure to space the tiles far enough part while the glue dries... Otherwise you'll invariably glue one magnet to another... and that isn't easy to fix.
Let your glue dry completely before moving on to the next step.
Add Comment
