Make a small light real Piano placed on your lap.and played like a real piano.It also can function as an exerciser for people who have to exercise their arthritic fingers.It will play 2 octaves with sharps and flats.
Remove these ads by
Signing UpStep 1INTRODUCTION
pleasing to hear and play.It can be used by patients who are bed ridden or arthritic and so the instrument can be used on the bed or lap. Hence the title.It only weighs less than 2 pounds and can be made from standard materials found in local craft stores and hardware stores .
An earlier Instructable initiated this instrument idea. That release the Mini-Piano was released back in an Instructable November 5,2009 and did not have sharps and flat keys.These were thus added here.
The piano was made in 40 hours of effort and not including search for the materials. Also any one who is a top craftsman may use up time on the wood and appearance if he wishes.I wish to enter this Instructable for the Health Contest.
The adhesion at the tip of the lever grabs the string and pulls it upword as you press the arm of the key down.. .
Then- after x grams of pull the adhesive releases the string and it vibrates freely for a few seconds.It stops when you release the key- arm -going down making contact and muting the string.
hope this helps visualize the operation.
I use weights to press the adhesive onto the strings as 20 grams. I could use wire springs but have not found any that will push at a accurate grams push down of the adhesive tip onto the strings.Im open to suggestions.
The key advantage to use of stretchable strings or cords is [a] ease of tuning and [b] very low stress used so that the tuner and frame are easy to make and of a lower material cost.
This is the main reason we used stretchable strings in our mini-instruments
We have been using stretchable strings since 2001.See instructables.
Now to simplify the steps... I am working on it and will publish it in my web page --
www.misticdiycrafts.webs.com .
Will definitely try when i have more than $5 on me. Maybe i'll experiment alittle. hopefully i can find/make a hammer system to it will play like a piano. All though no offence to this I just dont have arthritus. and think it would be cool to have something like this around, just with improvments.
Great Job.
and it is. May i suggest you try making the stringed instrument first minus the keying. My other Instructables go into detail on stringed instruments i have made.
When done you will have a Lyre to play if you stop construction now. Adding keys is a part B and may have to explain this more to you. The novel idea here is that the strings will be keyed using an thin adhesive double stick tape to pick up the string and release it when pulling the stick up forcfully. I have used this uglu adhesive preferably over other tapes as Scotch tape. It hold its stick to it ness -
No changes were seen for at least 3 years of playing my older instruments.
Is there a way to let the strings ring on, or does the weight of the key just act as a fret?
and finally cut and locating the adhesive pick ups just right. Other wise it is easy.
