Have you ever needed to hear a conversation in a room you are unable to access or bug easily? If so, and if that room has a window, you can using a laser microphone.
A laser microphone is a device that uses the vibrations of a window or similar pane of glass or plastic to record sounds near said window. A laser is pointed at a window and a photocell is placed where the laser's reflection lands. That photocell is then connected to a recording device. The vibrations of the eindow causes slight movements in the laser's reflection which, in turn, cause small fluxuations in the photocell microphone's current. This may seem complicated but it can be done cheaply and easily.
Step 1: Things Needed
The things you need for this build are very easily obtained and cost me about $10.
TOOLS
Soldering gun( or just electrical tape if you're being really cheap)
Scissors( if you're using headphones)
COMPONENTS
A laser pointer $1.50
A photocell $.30
A bad pair of headphones or, as I used, a speaker cable ending normal headphone jack $3.80
A tripod $0.00( already had one and isn't needed)
Recording device or computer with recording software
Step 3: How To Use
Using the tripod or other way to keep it steady, point the laser pointer at a window so that the reflection is in a spot that is not too difficult to reach. Now just position the photocell so that it's in the reflection. after doing that, connect the cord to the microphone plug-in and if you're using a computer, open your recording software. begin recording and it should pick up the sound.
Some tips:
If you want higher quality sound and less likelihood that people will see it, use a red laser to aim, then put an infrared laser( way too expensive for me and too hard to find) in it's place.
This project works best in dark places.
Curtains may help hide you but they muffle the sound quite a bit.
I had a sound file but there was a lot of light pollution in the room from an emergency light and the laser was being bounced off a clock's face which added a lot of background noise. I will upload a new sound file when i have a chance to make one.
Step 4: Thanks
Thanks for reading through my first instructable. If you liked it, please vote for it in the spy contest. Please don't try to use(or at least don't get caught using) this for anything illegal.
orangefult says: Jan 18, 2013. 2:05 PM
Couldn't you pull an infrared laser diode out of an old cd drive?
dad_a_monk says: Feb 15, 2013. 5:58 AM
I just got in a 480mw IR laser to try one of these. Will be making a guide as I do It. I have worked with the real thing once before I retired form law enforcement. Aiming the IR lasers are the fun part. We used a digital video camera but your phones camera can see IR qlso.
50-50 says: May 29, 2012. 4:33 PM
I am so anoyed at you for beating me to this idea, I was going to enter this but needed to order more photocencors.if you could better explane how this works you have a very big chance of winning.
Ian01 says: Jun 10, 2012. 5:18 PM
You might beat this if you find a way to make it ignore ambient light. (Hint: TV remotes do it.)
bioboy725 (author) says: Jun 11, 2012. 6:37 AM
One of the last steps already mentions infrared lasers. I just didn't have the time as I was going on a school trip and couldn't wait for the stuff to be shipped.
Ian01 says: Jul 3, 2012. 11:39 PM
I didn't mean lasers. I meant modulation.
bioboy725 (author) says: May 31, 2012. 9:40 AM
Well thank you for the feedback. I knew someone else would have the idea so I kind of rushed it. I bought everything that day and did it all quickly. I am working on improving the instructions now so I hope that helps.
Tanmay Das says: May 29, 2012. 7:31 PM
You can also use an infrared laser and receiver instead of ordinary laser.
IR is invisible to the naked eye so you won't get caught and also any other outside light will not interfere with the receiver.
bioboy725 (author) says: May 31, 2012. 9:42 AM
I mentioned that at the end but I was rushing to get this up before anyone else could, so it was poorly worded.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
