Everybody loves LCD monitors because they are so portable and perfect for LAN parties, but I am always afraid of something falling and damaging the soft screen when I travel with my LCD. After purchasing a nice 19 inch Dell display, I decided I needed something to protect my investment. I cut and molded a piece of acrylic plexiglass to form a cover for my LCD monitor.
Step 1Measure Monitor and Cut Plexiglass
In the image, you can see my plan for this project. I measured the dimensions of my monitor, and added 1.5 inches extra around each side. After cutting out the corners, I had to somehow bend the plexiglass on the dashed lines.
SWERDNA
To "ripple" a sizeable sheet without scarring the surface, you might be better off with the "drape" method: pre-build a (heat-resistant) "rippling" framework to lay it on, then heat the entire thing in a oven until the plastic "sags" into the form. Just be VERY careful of the heat setting(s) as plexi can FLASH into flames when it reaches the right (wrong!) temperature. (Just keep an eye on it - if it starts to "bubble", you've over-shot - it's already many degrees HOTTER than needed for bending, but will still be a little COOLER than the "flash" point, so you can prevent a fire...)
Alternately, depending on the thickness of plastic you want, there are several excellent 'ibles on building your own vacuum-forming jig...
I will try your method - I have a small piece of corrugated iron roof sheet with a nice ripple that should do the trick - I'll be standing by with fire extinguisher
You alluded to chemicals - I am an artist and stumbling into sculpture and accumulating knowledge as I go along - what chemicals will badly frost and/or craze the Plexi?!?! This sounds cool
Yours
Swerdna
If you dissolve some scrap bits in the chloroform it can be used as a glue.
DON'T BREATHE TOO MUCH OF THE SOLVENT IN, IT'LL QUICKLY KNOCK YOU OUT!!
