3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LCD Cover
LCD Cover
Everybody loves LCD monitors because they are so portable and perfect for LAN parties, but I am always afraid of something falling and damaging the soft screen when I travel with my LCD. After purchasing a nice 19 inch Dell display, I decided I needed something to protect my investment. I cut and molded a piece of acrylic plexiglass to form a cover for my LCD monitor.
Step 1Measure Monitor and Cut Plexiglass
In the image, you can see my plan for this project. I measured the dimensions of my monitor, and added 1.5 inches extra around each side. After cutting out the corners, I had to somehow bend the plexiglass on the dashed lines.
26 comments
Dec 1, 2010. 11:29 PMSWERDNA says:
Hi out there from darkest Africa! I am a total novice at manipulating Plexiglass - I have this concept of 'rippling' Plexiglass like a flag in the wind frozen in time - is a Heatgun the only method or are there chemical solutions to achieve this effect?
SWERDNA
Mar 14, 2011. 2:02 PMDr. dB says:
Chemicals would tend to badly "frost" and/or "craze" the surface while seriously damaging the molecular structure of the polymer - which CAN be used as "special effects", but that doesn't sound like what you're looking for.
To "ripple" a sizeable sheet without scarring the surface, you might be better off with the "drape" method: pre-build a (heat-resistant) "rippling" framework to lay it on, then heat the entire thing in a oven until the plastic "sags" into the form. Just be VERY careful of the heat setting(s) as plexi can FLASH into flames when it reaches the right (wrong!) temperature. (Just keep an eye on it - if it starts to "bubble", you've over-shot - it's already many degrees HOTTER than needed for bending, but will still be a little COOLER than the "flash" point, so you can prevent a fire...)
Alternately, depending on the thickness of plastic you want, there are several excellent 'ibles on building your own vacuum-forming jig...
Mar 15, 2011. 2:12 AMSWERDNA says:
Thank you Dr dB! (Hoping you are a real-live person and not a robot)
I will try your method - I have a small piece of corrugated iron roof sheet with a nice ripple that should do the trick - I'll be standing by with fire extinguisher
You alluded to chemicals - I am an artist and stumbling into sculpture and accumulating knowledge as I go along - what chemicals will badly frost and/or craze the Plexi?!?! This sounds cool
Yours
Swerdna
Mar 15, 2010. 12:05 PMmrsayao says:
how'd you cut it?
Mar 14, 2011. 2:08 PMDr. dB says:
Scoring'n'snapping works nicely, but does leave a somewhat-ragged edge needing scraping, sanding or "fire-polishing" to "pretty-it-up". If dimensioning were critical, you'd want to allow an extra half-millimeter so you can "dress it down" to precise measurements...
Jul 20, 2009. 4:23 PMifire says:
it's actually called a heat stripper, stephenniall! we make photo frames at our school! Does anyone Know how to stick plexiglass to itself? that I need to Know...Help!
Mar 10, 2011. 10:19 AMJUANKERR says:
If it's like English Perspex (methyl methacrylate) you can "weld" it with chloroform.
If you dissolve some scrap bits in the chloroform it can be used as a glue.
DON'T BREATHE TOO MUCH OF THE SOLVENT IN, IT'LL QUICKLY KNOCK YOU OUT!!
Oct 22, 2009. 7:02 PMJoe Otto says:
You could do it the easy way, buy a ShopShield. http://www.computerdust.com/
Jan 20, 2006. 6:04 PMaaron says:
will a hair dryer be hot enough to soften the acrylic?
Feb 21, 2009. 4:11 PMTommyhzy says:
LOL haha a HAIR DRYER XD
May 23, 2009. 1:15 PMXamith says:
I think that means no.
May 23, 2009. 6:03 PMTommyhzy says:
If you notice, each of those 3 comments were posted ~30 days from each other. Also, that means NONONONONONONO NO WAY! HAIR DRYERS are far too inaccurate, and the heat produced is not nearly enough to heat the acrylic before it cools again. Unless you happen to build sort of a tunnel for the hot air so it is recycled throughout, but that takes WAY more time to build than the time it might take to borrow a heat gun from a friendly neighbour...
May 25, 2009. 7:13 AMXamith says:
lol
Apr 16, 2009. 12:14 PMstephenniall says:
Hmm i did something like this for my psp At school with a small piece of acrylic and a Strip bender (think its called that)
Feb 23, 2006. 7:08 PMIIIIIIIII says:
(removed by author or community request)
Feb 21, 2009. 4:10 PMTommyhzy says:
Nice name though...
WHAT?!!!
Jan 24, 2009. 4:00 PMrobots199 says:
there is a very expensive dell monitor that features the same thing that you have but with glass
Jan 20, 2009. 4:07 AMmachineman says:
Hi Mvrogy, Cool thing you made from the acrylic...just one suggestion...this might help your cover from falling off the monitor...the upper folded part of the cover could be further folded 90 degrees downwards so that the cover keeps from falling off..but to do this you might have to remove the lower folding of the cover....
Apr 3, 2006. 6:54 PMZumbuda says:
I did something similar for my laptop that rides shotgun in the car with me. The display was too bright at night, and instead of fiddling with the brightness controls, I built something like this that slips over the top (and slips right back off) lined with window tinting from WalMart. Works great, still readable, but the cops don't pull me over anymore. It's only running a GPS officer...
Jan 19, 2006. 9:14 AMvrogy says:
Basically, just a 3/8-1/2" hole drilled at the corners where the bends meet(before bending) to prevent the lexan from cracking- which a tight enough radius with .1" will do pretty easily. Another thing that's occured to me is that it'd be pretty easy to just add some extra bends to the side tabs so the whole thing will snap onto the LCD. Might try that as soon as I get some 1/16" stuff.
Jan 19, 2006. 7:34 AMtheo2112 says:
for the general public, I have purchased lexan from the home depot. I dont know th exact thinkness, but it was no doubt less than 1". They have a (rather) large selection of it with different tints, thicknesses, and "breakabilities" (?) Prices range from 3$ - lots of $'s
Jan 19, 2006. 5:45 AMvrogy says:
You know, some circular relief cuts at the corners might be a good thing if anyone uses thicker plastic- what thickness is herein used? For the general public, acrylic and lexan can be bought in .1" thick sheets at Home Depots, but to get some really nice-to-bend 1/16" (.0625ish) lexan, McMaster is my favorite.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
44
Author:matthewbeckler
A PhD student in Electrical and Computer Engineering at Carnegie Mellon University in Pittsburgh, PA.
