Step 2Bending The Plexiglass
iImage Information
I talked to a few glass stores in town, but I couldn't find anybody who would bend plexi. I did some research online and found that some people had successfully used a heat gun and very gentle pressure, so I decided to try it. After borrowing a heat gun from my roommate's girlfriend's mother, I set up a crude heating and bending mold with a piece of wood and a metal level. I applied the heat gun to the gap between the block and level, and very, very carefully, the plexiglass started to soften and melt. As the acrylic starts to melt, the pressure from the block will start bending it. I needed to tack down the level, because it had a tendancy to scoot to the right as the bend progressed. Eventually, you will need to apply pressure to the left edge towards the level. Once the plexi is bent at 90 degrees, turn off the heat gun and let it cool right here before moving it. I moved the first edge before letting it cool, and it flexed back to about an 80 degree angle.
You can see in the last image my progress after bending two of the sides.
SWERDNA
To "ripple" a sizeable sheet without scarring the surface, you might be better off with the "drape" method: pre-build a (heat-resistant) "rippling" framework to lay it on, then heat the entire thing in a oven until the plastic "sags" into the form. Just be VERY careful of the heat setting(s) as plexi can FLASH into flames when it reaches the right (wrong!) temperature. (Just keep an eye on it - if it starts to "bubble", you've over-shot - it's already many degrees HOTTER than needed for bending, but will still be a little COOLER than the "flash" point, so you can prevent a fire...)
Alternately, depending on the thickness of plastic you want, there are several excellent 'ibles on building your own vacuum-forming jig...
I will try your method - I have a small piece of corrugated iron roof sheet with a nice ripple that should do the trick - I'll be standing by with fire extinguisher
You alluded to chemicals - I am an artist and stumbling into sculpture and accumulating knowledge as I go along - what chemicals will badly frost and/or craze the Plexi?!?! This sounds cool
Yours
Swerdna
