LCD Display With Arduino( How to Use the LCD)
4,582
33
6
Posted in TechnologyArduino
Introduction: LCD Display With Arduino( How to Use the LCD)
In the following section we are going to see how to use the lcd display with a microcontroller and also see the basic of the lcd over here by making a simple shield for the arduino or by making the simple breakout board for the lcd to the arduino
Step 1: Watch the Video
Step 2: Basics of the LCD
The basic data of the 16x2 lcd are given by
FEATURES
• 5 x 8 dots with cursor
• Built-in controller (KS 0066 or Equivalent)
• + 5V power supply (Also available for + 3V)
• 1/16 duty cycle
• B/L to be driven by pin 1, pin 2 or pin 15, pin 16 or A.K (LED)
• N.V. optional for + 3V power supply
And the pin diagram of the lcd is given in the pitcures above and the functions of the pins are also given above with each pin defination
Step 3: Creating the Basic Shield for the LCD to Work
by using the following circuit diagram of the shield making for LCD and as you have already watched the video you will get some basic idea about the circuit diagram of the lcd and their connections
The pins which we are going to use to connect it to any external microcontroller or microprocessor
RS(PIN=4)
E(PIN=6)
DB4(PIN=11)
DB5(PIN=12)
DB6(PIN=13)
DB7(PIN=14)
Step 4: Connecting to Arduino
To make the LCD to work with there is one missing component that is microcontroller that could be any like the 8086 or pic microcontroller in my case i have used a arduino uno
The pins which are being used in the following session are
Arduino pins LCD pins
12 RS
11 E
5 DB4
4 DB5
3 DB6
2 DB7
connect all the following wires to the arduino and the LCD
Step 5: Uploading the Code to Arduino
To fetch the sketch to the arduino you need to open the arduino ide and then you can follow the example code as
file-example-liquid_crystal-hello world
from the liquid crystal library to test the module the hello world example will be the best one
there are certain commands for the lcd and the arduino which are given in the arduino website
the link to the liquid crystal refrences
https://www.arduino.cc/en/Reference/LiquidCrystal
Step 6: Thanks for Watching
SO THANKS FOR WATCHING THE FOLLOWING INSTRUCTABLES.
FOLLOW ME ON YOUTUBE CHANNEL
https://www.youtube.com/channel/UCZE35bOktFxu8dIad...
thanks for the support
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    6 Comments
    This looks like what I've done this morning in my Instrumentation laboratory!
    Nice
    thanks and yes it was done in the morning only XD
    I used this code:
    #include
    LiquidCrystal screen(12,11,5,4,3,2);
    byte acento[7] = {B00001, B00010, B00000, B01110, B10001, B10001, B01110};
    int x=0, y=-5;
    void setup() {
    // put your setup code here, to run once:
    screen.begin (16,4);
    screen.createChar(0,acento);
    void loop() {
    // put your main code here, to run repeatedly:
    screen.setCursor(x,0);
    screen.print("Universidad Aut");
    screen.write(byte(0));
    screen.print("noma ");
    screen.setCursor(y,1);
    screen.print(" de Baja California");
    x--;
    y++;
    if(x==-20){
    x=0;
    if(y==15){
    y=-5;
    delay(500);
    screen.clear();
    great work and thanks for posting it back as feedback
    not really but it took 6-7 hours of work
