3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LCD Overhead Projector
Looking for the Instructable? Sorry, it's been moved here
84 comments
1-40 of 84next »
Dec 11, 2009. 11:56 AMDerin says:
Would the Liesegang trainer portable T work?It shines from above and replaces the clunky frame with a slim mirror.
Jul 10, 2009. 4:14 AMCoggz says:
Hey, I've got a slim ohp here that shines the bulb down and mirrors it back up. Would it work the same? I got the ohp for £20 and it would be great as it is slim. It is this projector: http://www.vega.si/eng/?template=product&art=9 I hope this works as it would be the cheapest projector ever...
Luke
May 29, 2009. 4:47 PMadd.thebad says:
would it be possible to do a similar thing but use a high power garden lamp and mirrors because i don't have a ohp
May 29, 2009. 4:46 PMadd.thebad says:
Apr 19, 2009. 11:36 AMadin99 says:
hey waterppk my name is adin and im attempting to build one of these projectors from your guide. I have gotten to the step that requires me to extend the LVDS cable. Thanks to your comment to ongissim i was able to find the extension cable on digikey. Now i have the cables but am wondering where to go from here... What type of wire do i need to use to connect the parts, and how exactly do i do this, hey thanks a lot in advance -Adin PS please respond here or email me at adin99@gmail.com Thanks!
May 11, 2008. 6:57 PMongissim says:
I have the same problem with the FPC cable being in the way of the screen. However, when I search Digikey, I can find the connectors, but not the 16 pin cable. What was the model number of your cable? Also, was your pin pitch .5mm?
Apr 16, 2009. 3:24 PMadin99 says:
Mar 21, 2009. 4:45 PMursula_c says:
i tried to make one, but the lcd screen wont stay on. it flickers on and off, anyone know how to fix this problem?
Feb 1, 2009. 7:27 AMlardbob says:
I made one and it works perfectly, apart from a white line of dead pixels down the screen because one of the screen address cables got damaged :( Nice instructable!
Aug 7, 2008. 8:30 AMjcdj says:
cant you just replace the bulb in the projector with a worklamp light bulb, it would get much brighter, right
Aug 11, 2008. 9:31 AMjcdj says:
ohhh, ok i uderstand what your saying, i was asking cause im gonna use my lcdprojector for a multi touch computer screen,
http://www.instructables.com/id/Back-projection-56-inch-multitouch-television./
i dont want to use a worklamp bulb if it has more IR output then a projector bulb, because it would mess with what the multi touch input, is their a brigther bulb i can get because i want a really crisp picture....
Sep 14, 2008. 5:56 PMxeniczone says:
You could take a shot with Metal Halide, they will put out around 20,000 lumens and will be close to white light which is 5000K. Either way you need to take a IR filter and put on the front of them. Because if you use a Worklight you are putting yourself at risk with the amount of IR that comes of them. Worklight will put you at risk of getting sun burn without the IR glass filter. I think the same is for the Metal Halide.
Dec 26, 2008. 7:30 PMbarrywilliams says:
Just to clarify . . . There is no real exposure risk from the infra red (IR) from the lamps. The real hazard is ultra violet (UV). Metal halide and halogen both have integrated UV filters. The real problem with these high-output lamps is the IR can damage the LCD. Overhead projectors have a filter in them and they use a dichroic mirror that allows the IR to pass through the back and reflects the rest. If you've been to the dentist you've seen a dichroic mirror.
Dec 23, 2008. 11:48 PMalsyan says:
can i use 3m the five "o" eighty eight to build a LCD video projector thank's
Oct 20, 2008. 4:12 PMjeoncs says:
Just a random thought but would a portable DVD Player LCD be able to do this as well? That would be cheaper and nice for a stand alone unit without the computer.
Sep 29, 2008. 11:31 AMdelliott87 says:
a. i bought a RCA to VGA adapter cable thinking i could run it from the cable box to the monitor but now i see (a little lower on the comments) that probably won't work...what would you suggest to run my cable rca output to the monitor? b. i cannot figure out what to do about the ffc cable...what do you suggest? it seems like i could solder directly to the board on one side but the other one has a connecter the cable used to slide into. any thoughts?
Sep 23, 2008. 8:12 AMbogaloids says:
hey this is a great project.. just wanna ask if you can send me a wiring or schematic diagram of this so that i can easily construct mine.. thanks alot!!
Aug 7, 2008. 7:19 AMnursgon says:
will this cable work? I have all the parts just trying to figure out how to get the movie to the LCD screen. I thought if I hooked this cable to the LCD then ran a RCA video from my DVD player it would work.
Sep 14, 2008. 5:47 PMxeniczone says:
No, That cable is just an adapter, it is made for a projector or a LCD screen that already has the converter built in. It won't just work on any LCD screen.
Aug 20, 2008. 6:01 AMnursgon says:
Got the cable and it don't work you need a converter to change video single to VGA or use a LCD screen that was made to go from monitor or TV. my brother sent me a LCD flat screen with both hook ups on the monitor, I will try to build with it.
Aug 10, 2008. 8:12 AManimefanatic says:
would it be at all possible to use a CRT monitor... I have a bunch of them and do not know what to use them on.
Jul 30, 2008. 2:12 AMdjlaurenx says:
Im confused... what are we hooking up to the monitor in order to play movies or dvds? This part is confusing and seems to be not clarified in this or your other projector instructable... Am I hooking up a dvd player to this? and where? or to another computer? via what port???? THANKS
Jul 31, 2008. 6:23 AMdjlaurenx says:
Sweet, thanks for the prompt response. I have an LCD monitor on a dinosaur laptop, so it has no dvd drive :( ... just trying to figure out an alternate method to do this as there are tons of 10.00 overhead projectors for sale in my area right now! lol
Jun 22, 2008. 11:39 AMsnarblarg528 says:
Hi I was wondering how much screen resolution mattered. I've seen a few dirt-cheap 12-13" LCD monitors on eBay but their max resolution is 800x600, and then I've also seen some cheaper 14" or so which run at a 1024x768 res. Are these "good enough" for wall projection, or are very high-res monitors much preferable?
Jul 13, 2008. 12:36 AMmelsoftm says:
higher the resolution the better !! =) good luck !
Jul 13, 2008. 12:18 AMmelsoftm says:
Hey this is an awesome Idea! I had a spare lcd screen and found a projector for 25 dollars on craigslist, the setup worked perfectly, but then my projector system failed, I looked further into and it seemed that my system had browned out! I saw that others have posted that their setup had browned out but their descriptions didn't fit how my system failed, so I took the multimeter to it =P, found out that there wasn't enough load on the circuit so my chip set fried =(, the back light was the load that was missing from the whole setup =(, I was planing to use the lead to power my fans to cool the screen, but unfortunately my setup died before I could =(, looking for another screen now! I love this idea!
Jun 27, 2008. 10:56 PMDhetshi says:
What if I use a 9 inch LCD will it have good picture and resolution. Answer my question to htea_@hotmail.com Thank you
Jun 13, 2008. 11:30 AMSelf-Serving Martyr says:
How much do the replacement bulbs for the overhead projectors usually run?
1-40 of 84next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:waterppk
I'm working on my Master's of Science in Mechanical Engineering, specializing in Engine Research at the University of Wisconsin - Madison. ***All Instructables Projects moved to my personal site, I di...
more »
