LCD Thermostat
Published
Introduction: LCD Thermostat
Build an arduino thermostat that displays the current temperature and a desired temperature set by the user using the potentiometer. when desired temperature a "fan" is turned on which is actually just an LED.
Step 1: Build Circuit
What you will need:
- Jumper Wires
- 16x2 LCD Screen
- 2 poteniometers
- TMP Sensor
- Button
- LED
Step 2: Write Code
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
Serial.begin(9600);
lcd.begin(16, 2);
pinMode(13, OUTPUT);
void loop() {
int tempreading = analogRead(0);
int button = analogRead(1);
int selectC = analogRead(2);
selectC = map(selectC, 0, 1023, 12, 32);
int selectF = (selectC * 9.0 / 5.0) + 32.0;
float voltage = tempreading * 5.0; voltage /= 1024.0;
float temperatureC = (voltage - 0.5) * 100 ;
float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;
int plusF = temperatureF + 2; int minusF = temperatureF - 2;
if (button < 1023) {
lcd.setCursor(0, 0);
lcd.print("Desired: ");
lcd.print(selectF);
lcd.print("F");
lcd.setCursor(0, 1);
lcd.print("Temp: ");
lcd.print(temperatureF);
lcd.print ("F");
else {
lcd.print(selectC);
lcd.print("C");
lcd.print(temperatureC);
lcd.print ("C");
if (selectF >= minusF && selectF <= plusF){
digitalWrite(13, LOW); } else {
digitalWrite(13, HIGH); } delay(1000);
Serial.println(temperatureF); }
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    I think I could use this. I have two questions.
    1) Are the 2 poteniometers both 10K?
    2) What function does the button serve?
    Thanks!
