Step 3Plate to projector
Once you have securely fastened the speaker mount to the plastic plate it's time to drill holes!
*(This part was inspired) take some unused rivets and put them in the mounting holes on the bottom of the projector.
Place the plastic plate... with the speaker mount facing up... on top of the rivets that are sticking up and give the plate a somewhat light tap
(this will force the rivets to make little indents in the plastic plate in the exact location you will need to drill the holes!)
Drill holes in the plate to access the mounting holes on the projector by drilling where the rivets made their little marks.
Set the plastic plate, with the speaker mount pointing up, on the bottom of the projector so the holes line up with the mounting holes on the projector.
Using the screws connect the mount and plate to the projector. *(Yes the projector is up-side-down)
*(if you projector weighs more than 10 lbs. you might consider using two speaker mounts. If you projector is more than 22 lbs. use something else!)
Add Comment
