Step 11Circuit Description - Level Offset; Trigger Circuitry
A DAC of same type also sets the adjustable trigger level. Since the DAC can only produce voltages from 0V to 4.096V, one half of OP3 scales this up to the full necessary range of 0 to 5V. The second half is configured as an open-loop comparator, i.e. an op-amp without any feedback circuitry and as a consequence very high gain. It is fed by the trigger level on one side and the ADC1 input voltage on the other. This circuit will rail to the positive supply voltage whenever the input signal exceeds the trigger threshold ever so slightly, and rail to ground whenever the input signal is only sightly lower than the threshold. In other words, it provides a digital trigger signal that feeds the trigger input of the sample logic.
In the present circuit the scope can only trigger on channel 1. This is not really a serious limitation, the user simply must decide which signal he/she wants to trigger on before hooking up the scope to his/her circuit. At the same time, it cuts down on components, board size, and cost (at least two more ICs and some discrete elements).
Add Comment
