3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LCS-1M - A Full-Featured, Low-Cost Hobby Oscilloscope
Step 20Build Your Own Step 5 - Connectors, Voltage Regulators
Now come the connectors - power (left bottom), PC link (left top), and probe (right), as well as the two voltage regulators. Not all of the connectors shown are mandatory:
If you plan to put the board in an enclosure, you can safely omit the black power connector (keeping only the blue power terminal), the phono socket, and the board-mount BNC connectors (not installed in the picture above). Installing the through-hole BNC connectors will prevent you from fitting the board into the intended enclosure, and those connectors are very hard to remove once soldered on.
On the other hand, to keep the scope as a bare unit, you may not need the blue power connector (if you are using a power supply with coaxial plug), and can also omit the three-pin serial header (J_SERIAL).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:womai
