3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LCS-1M - A Full-Featured, Low-Cost Hobby Oscilloscope
Step 23Build Your Own Step 8 - Component Leads
If you haven't done so, once you are done soldering, clip all the component leads with the wire cutter. Be careful - wear glasses or at least close your eyes when cutting - sometimes those leads can shoot away with quite some force and you don't want them to land in your eyes!
This step is also a good occasion to check every single solder joint and make sure you actually soldered each and every component lead. Double-check all the chip socket leads as well - it is very easy to forget to solder some, which best case makes for an extended troubleshooting session, and worst case could cause damage to the chip when powered up. Also make sure all the solder joints look "good" (shiny and smooth surface - anything else could indicate a "cold" solder joint that does not really make good contact and/or will break open and lose contact in the future). If necessary, re-heat suspicious joints to re-flow the solder.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:womai
