Step 7Circuit Description - Sample Logic
Originally I designed the scope using a Xilinx CPLD (programmable logic device), but in the end
decided to employ standard CMOS logic chips (74HCxx series) instead - a CPLD again needs special programming hardware and software and I figured that would probably put off everybody except a few experts. It also knocked a little bit off the component cost. This forced me to really reduce the logic content to an absolute minimum, so thats why there is e.g. no pre-trigger option (i.e. a possibility to capture the signal before the trigger). Maybe I'll make such a scope in the future.
The microcontroller supplies a clock signal (produced in the background through its PWM output)
which is gated (blocked) until a trigger impulse arrives through flip-flop DFF1. The XOR in front of
DFF1 acts as a programmable inverter to select triggering on either rising or falling edge. In front of it is a Schmitt-trigger logic gate that adds some hysteresis to minimize the chance of false triggering due to noise.
The clock signal drives a 8-bit binary counter (CTR1) which increments the address for the data
storage in the SRAM (see next page). When the counter wraps around (i.e. after reaching its
maximum, and the most significant bit goes again from 1 to 0) this triggers another flip-flop (the
second half of DFF1) which in turn gates off the clock signal. The other output (Q) of the flip-flop
produces the "DONE" signal which indicates to the microcontroller that the data acquisition has ended and the data can now be read from the sample memory and transferred to the PC.
For this readout, the microcontroller re-enables the clock path and alternately pulses the clock signal and reads out one bye of sample data, which it transfers to the PC through the serial connection.
Add Comment
