Introduction: Arduino LED 4x4x4 Cube With 595 Shift Registers DIY Kit
Picture of Arduino LED 4x4x4 Cube With 595 Shift Registers DIY Kit
This is a 4x4x4 LED cube kit from Ebay costing about £3.50. It uses 2 x 74HC595 ICs to drive it. The kit comprises of a circuit board, 2 x ICs, 2 DIP Sockets, 70 LEDs, 6 resistors, and 2 x 40 rows of pins, but NO INSTRUCTIONS! I asked the supplier if there were any but did not get a reply. Anyway looking at it, I thought it should not be so difficult as there are some printed bits on the double sided board.
Anyway this is the result - IT WORKS!
There are 16 pins for the anodes which are connected to the output pins of the two 595 ICs. The four planes are connected to the arduino (pins 7,6,5,4) through 4 x 500 ohm resistors.
I have tested it on both the UNO & MEGA. The pins used are hard wired into the shield.
74HC595 pin ..... Arduino
SH - Clock................0
ST - Latch.................1
OE - Output Enable..2
DS - Data..................3
Shield
D16...........................4
D17...........................5
D18...........................6
D19...........................7
Step 1: Solder the Components to the Board
Picture of Solder the Components to the Board
1. Solder the resistors to the the board.
2. Solder the DIP Sockets next.
3. Solder the round pins into each location (D0 - D19). Rather fiddly.
4. Solder the 4 blocks of long pins.
Step 2: Assemble the LEDs
Picture of Assemble the LEDs
I have no photos of the assembly, but looked at what others had done for their cubes
1. Make some sort of template to hold the LEDs in place.
2. Check each LED is working.
3. Bend legs.
4. Solder all 16 LEDs together (Cathodes).
5. Check that they are still all working!
6. Do this 3 times more.
7. Solder each layer together (Anodes).
8. Insert bottom layer into PCB pins and solder if required.
9. Connect the ground planes to D16, D17, D18, D19. (There were no wires in the kit to do this).
10. Enjoy your creation.
Step 3: Write Some Code
This code works with the Arduino UNO & MEGA.
There is a routine to deal with the code snippets that you find all over the internet in both code samples.
led4x4x4checker was written from scratch by myself.
LED4x4x4with595s is code I modified from another instructable.
UnPolacoLoco made it! (author)2017-07-30
Very nice build. Super useful to practice shift register usage with the Arduino.
tomatoskins (author)2015-10-15
Shift registers are so helpful!
About This Instructable
2,935views
10favorites
License:
Bio: I like tinkering with electronics, PCs, ESP8266s and Arduinos. Would like to share what I have done as it may help others getting started or ... More »
More by JohnL142:NODEMCU Lua ESP8266 With Real Time Clock (RTC) & EEPROMNODEMCU LUA ESP8266 with MCP23008 8 Bit Port Expander ICNODEMCU LUA ESP8266 With MCP23017 16 Bit Port Expander IC
Add instructable to:
