Tools you need:
Altoids Gum Tin
Soldering Iron
wire cutter or caliper
Battery Clip for 2xAA batteries
2 AA batteries
1 old IDE cable
Hotglue
20min of your life ;)
By the way.. I was inspired by this awesome Instructable:
http://www.instructables.com/id/Bread-Board-from-IDE-Cables/
Remove these ads by
Signing UpStep 1Find empty Altoids Can
Besides the gum tastes delicious.
*But don't eat all at once..*
But I do have some like the yellow, orange and red ones that are about 2.1 -2.4 Volts
Maybe if I make this I'll include a switch for supplying either 2 Volts or 3 Volts.
Just need to add a resistor and a bit of wire and a switch as far as I know.
actually i made a joul thief for testing.. that works with just one battery.
I have to make shure the 20mA are still bright - as you said.. would be sad if you can barely see anything like the LED tester on my Multimeter..
R = (U - Uled) / I
R is the resistance
U is the voltage from the Batteries
Uled is the voltage the LED needs
I is the current the LED needs
in your case: R = (3 - 1.7) / 0.015 = 1.3 / 0.015 ~ 86 Ohm for a red LED.
mfg Daniel
maybe your example makes sense, cause it's almost the lowest LED Voltage it could get..
I'll see if I open it up again someday to keep the nice altoids tin
and then decide to put either the regulator or the resistor in the circuit.
.. by the way.. here is a sweet online calculator: http://ledcalc.com/ VERY useful
thats what my father thought me, please correct me if im wrong.
