3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Belt
Step 10Put It On!
Put It On!
  • E:\LED BELT INSTRUCTABLE\DVC00031.JPG
  • E:\LED BELT INSTRUCTABLE\DVC00054.JPG
The belt should now be complete.
The snap will act as an on off switch. Sure, you could add an on/off switch if you like.
IMPORTANT: The battery dies within a couple of hours, so i suggest a rechargeable set of batteries. Double A rechargeables are the most common, if you cannot find nine volt rechargeables and three double A's will work, but you would need something like an altoid tin to hold them in. Belt Buckle Maybe? You could also go to cheapbatteries.com, if you didn't know that the site existed.
FYI: if a LED, were to say, snap off, you could easily replace it, but to prevent that from happening, you need to be gentle when putting it through the loops in your pants. It is pretty durable, though, and the LEDs can take a beating before they fall off.
QUESTIONS AND COMMENTS ARE WELCOMED, POSITIVE OR NEGATIVE
15 comments
Sep 27, 2011. 8:17 AMzmanalansan says:
Are they waterproof? Is it safe to use if you got wet?
Aug 7, 2009. 7:12 AMJAGleason11 says:
I tried to make this with different LEDs alternating color for my school colors. Old Gold and Blue for WVU but the LEDs wouldn't work I found out that resistors are required if you want to alternate because the current needs to be identical for each LED or it won't work in a parallel circuit. Just FYI
Apr 4, 2009. 6:29 PMZem says:
Nice Ible'. If I do add a resistor, do I only add one? Or one at each LED?
Mar 29, 2009. 11:21 AMelinventor21 says:
wouldnt that battery be to much for the leds? i still dont get that if each led can only take about 3v then how can u use a 9v battery is it because they are in series? please respond a.s.a.p.
Dec 11, 2008. 11:09 AMwax54 says:
I am going to use this at school it was hard to make but worth it
Oct 4, 2008. 4:29 PMDANHOENIG says:
GREAT AND COOL. CAN I MAKE THIS EASIER BY BUYING LED LIGHT STRINGS AND ATTACHING A BATTERY TO IT?
Oct 4, 2008. 11:44 PMJamesRPatrick says:
WELCOME TO INSTRUCTABLES! IT'S GREAT TO FIND SOMEONE ELSE WITH A BROKEN CAPS LOCK. You could try that, but it's usually more fun to make a project yourself.
Oct 5, 2008. 7:48 AMDANHOENIG says:
YEH, CAPS LOCK....I NEED TO GET IT FIXED. SINCE I AM ELECTRONICALLY CHALLENGED, IF I JUST CUT THE PLUG OFF THE END AND ATTACH TO A BATTERY, WILL THAT WORK? IF SO, WHAT KIND OF BATTERY POWER DO YOU THINK I NEED? THANKS
Oct 5, 2008. 11:53 AMJamesRPatrick says:
That setup would be specific to the LED strip. It would probably be easier to build it to the specs of the power source, not the other way around.
Jul 22, 2008. 5:37 PMrambolinda says:
Can someone tell me just exactly what is "stranded wire"? Went to Radioshack and got everything but didn't know what stranded wire was. Is there another name for it? What does it look like? Thanks! Linda
Jul 24, 2008. 10:06 AMJduffy says:
Let's take some 12 awg wire. Solid wire would be a solid copper rod covered in insulation. Stranded wire is the same wire gauge, but it is composed of many smaller wires wound together.
Jul 24, 2008. 10:26 AMrambolinda says:
Ok, so when i strip the plastic coating off, would i only be using one strand of the smaller wires that are wound together?
Jul 29, 2008. 10:56 AMJduffy says:
Yes, you would only use one strand.
Jul 11, 2008. 12:33 AMtj the gnome says:
wow, i like this. probably because you labeled EVERYTHING!
Oct 28, 2007. 6:40 PMskaskank says:
cool instructable, i'm gonna make this one of these days
Oct 14, 2007. 5:00 PMandrew.mac says:
great instructable, where and how much did the leds cost again ???
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
93
Author:Doctor What
