Materials:
conductive paint
conductive epoxy
5-minute epoxy (hot glue for grownups) or hot glue and gun
wooden sticks or plastic coffee stirrers for mixing and applying epoxies
9-volt battery
magnetic reed switch
magnet(ring-shaped for tethering)
LEDs(white and red if law in your state mandates, or your choice)
clear spray enamel(for coating circuit to protect from rain-shorts)
wire
solder
moist paper towel
bike helmet
Tools:
pencil
soldering iron
wire cutters/strippers
needlenose pliers
masking tape
paint brush
fine grit sandpaper or sanding block
solderless breadboard for prototyping (optional)
Flickr set available.
Project home page on Sternlab.
Step 1: Prep your materials
Test your LEDs to make sure they work, and work out what your circuit will look like. Since I'm using a 9v battery, I'm using three white LEDs for the front in series wired with four yellow in-series LEDs, and the two sets are wired in parallel (see circuit diagram). See what works best for you, and try it out on the breadboard before you commit to the design on your helmet.
Prep the helmet:
Lightly sand the surface to allow the paint to bond more easily. I also took this opportunity to sand off brand logos from my helmet. Follow the sanding with a thorough wipedown with a damp paper towel or cloth. I'd avoid using any cleaner here, since who knows what chemicals are in it and what they might do to your circuit. Water does just fine. Be sure the helmet is completely dry before doing any painting.
Step 2: Draw and tape the circuit
Step 3: Paint the conductive traces
Paint inside the stencil you've just made. Make sure to stir the paint thoroughly and often, as the particles have a tendency to settle. I applied two coats. Refer to manufacturer's instructions for optimal paint thickness.
Touch ups:
Let it dry a little, but not all the way, and peel the tape off carefully. I took the tape off before the paint was dry to make sure none had bled under the paint, shorting the circuit. I touched up any bleeds with my damp paper towel.
Let the paint dry for at least two hours before attaching components. My paint's instructions said that it reaches full dryness (and therefore highest conductivity) after 24 hours.
Step 4: Prepare components
Lay out your LEDs and trim their leads (but make sure you keep track of the cathode and anode orientation). Mix some 5-minute epoxy and affix the battery and switch to the helmet. Allow to dry. position wire ends on paint traces and lay out ALL LEDs before mixing the conductive epoxy (so as not to waste time once its mixed)
Step 5: Affix LEDs and wires with conductive epoxy
Step 6: Seal and wear with pride!
I affixed my magnet to the strap with a cord, so it's always with the helmet. I simply reach up and touch it to the switch to turn it on!
Design note: I avoided placing traces or components on the top of the helmet, as that is the surface on which it rests when the helmet's not on my head, and I didn't want to risk scratching up my circuit or damaging the components.
![pimpMyBike[1] =](http://www.instructables.com/files/deriv/FAO/AC1G/H9T4FC2Q/FAOAC1GH9T4FC2Q.SQUARE.jpg)
Visit Our Store »
Go Pro Today »
Then there's this: Cyclist's Head Run Over By Truck, Saved by Helmet
http://www.treehugger.com/files/2007/05/cyclists_head_r.phpOtherwise this is pretty cool. You're going to wear you helmet, and you're not going to leave in on the bike = always have your lights.
L
(learn to smile)
And to be honest, I just happened to be out of red LEDs when I made this.
