- They have perfected the LED rear blinky light, don't make your own unless you really want to (I like the Blackburn Mars 3.0 )this is not to discourage you from making your own if you really want to, I'm just saying this blackburn light is bright.
- The headlight is crazy bright, and can be brighter...
This version just has 15 more LED lights, a hi/lo switch and foregoes the rear blinky part.
Remove these ads by
Signing UpStep 1Parts
DPDT Switch
9v battery snap connector (if needed, my 8aa battery holder needs it.)
8aa holder.
Reflector mount.
Breadboard ( I used the PC-403)
http://ledcalculator.net
Since you're running parallel strings and haven't carefully sorted the individual Vf figures of each LED to come up with balanced strings, you should really have individual dropping resistors per string. They can be fairly low value, just an ohm or two if you can get 'em. If these are omitted, you'll likely end up with a situation where one string, because of Vf variations in the LEDs, passes more current than the others, and since LEDs have a positive temperature coefficient, begins to take even more current, eventually destroying itself.
It looks awesomely bright in the meantime, though. :)
The lack of resistors or a current controller will ultimately fry this design, but until then: "FLAME ON!"
I liked the design where the whole board and part of the LEDs was encased in plastic, allowing all the LEDs to generally be at the same temperature and avoiding the thermal runaway action that would lead to a burn out.
My .02$
srry some times my cpu puts in weird stuff
