3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Binary Clock
Step 5Solder display
Solder display
For the display you need 17 surface mount LEDs, 6 100 ohm surface mount resistors, 11 zero ohm links and 9 2cm lengths of bell wire. Solder them to the PCB as per the diagram below, ensureing you solder the LEDs in the correct orientation.
The display board shown here is a newer version than is used in the rest of the photos in this instructable, it has fewer resistors so is easier and cheaper to make.
Care must be taken when mounting the zero ohm links (resistors with zero resistance) as there are tracks on the PCB running between the 2 solder pads, the links must be positioned so that neither of the metal terminals touch the PCB track between the pads.
2 comments
Feb 1, 2010. 1:55 PMmoapz says:
can I use bell wire instead of zero ohm ?
why zero ohm ?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:ElevenOf9
