Introduction: LED CAR TAIL LIGHT CONVERSION | HOW TO CHANGE BULBS ON DODGE RAM PICKUP TAILLIGHTS | INSTALL,REPLACEMENT
hi everyone, this is geramicc85 and today i will show you how to change the bulbs on the dodge ram taillights. All you need is a replacement bulb 3157 and a Torx T25 Screwdriver. I am going to install these LED bulbs instead of the 27 watt stock bulbs. First thing is to drop the tailgate. Now for the replacement i have to take out the tail light unit. 2 Screws hold the unit from the inside of the bed. You find them right here. Take your T25 Screwdriver and take out both of the screws. Now you can start on the bottom and grab the unit like that with your fingers. Pull it towards the rear on the bottom and on the top for an evenly slide out. Now I'm laying it onto the tailgate for an easy bulb access. Now i can turn the this bulb socket contra clockwise until it comes off. Now i can just pull out that 3157 style bulb like that and put the new led bulb in. Make sure the bulb lights up before you put the unit back together to see if its operating correctly. Now you can reinsert the socket. Make sure to insert it the right way there are three different size notches. Then turn the socket clockwise to the end for a secure hold. Now i am putting the tail light unit back in by making sure to insert the two spikes into these holes. i am checking the wires so that i dont squeeze them. I push firmly onto the light unit until it slides back in its position. Put the two screws back in to secure the unit. Thats it guys, thanks for watching and feel free to subscribe for more dodge ram how to videos. Take care, geramicc85 signing out.
gunguru (author)2015-09-19
you can't do a LEDbulb replacement on an older vehicle unless you install an electronic flasher into the circuit. The way older car's blinked the turn signals was to use a unit that blinked the circuit when it felt resistance....... thats why your lights blink faster when a bulb burned out. Less resistance, faster blinking........no resistance (like with LEDs) and the circuit won't blink at all.
Nobilis (author)gunguru2015-10-01
That's true. However, if you sacrifice low energy consuption you can imitate the resistance of a conventional light bulb by wiring a 5W ceramic resistor to the LEDs. This way you do not need a flasher circuit and the old relay type flasher can be used.
bobbydee (author)Nobilis2016-12-07
or...
you can also purchase electronic flashers, that take literally 15 seconds to change, on Amazon for about $9
BeachsideHank (author)2015-09-18
Do you have a link to the LED replacement for the 3157 lamp?
Thanks.
About This Instructable
1,553views
12favorites
Bio: Hello Friends! This automotive channel is about repairs, modifications and upgrades on my 2nd gen. Dodge Ram. I make videos in english, german and spanish ... More »
More by geRAMicc85:BALL JOINTS REPLACEMENT ON PICKUP | HOW TO PRESS IN UPPER+LOWER | REMOVE,REPAIR,INSTALL IN DETAIL | DODGE RAM TRUCKHEATING PROBLEM SOLVED ON PICKUP | HOW TO FIX GURGLING HEATER CORE | DODGE RAM TRUCK NO HEATLED LICENSE PLATE CONVERSION BULB REPLACEMENT | DODGE RAM 1500 | HOW TO DO SMD LIGHTS MOD
Add instructable to:
