Step 5STEP-5
About Flicker:-
There is a very minimum of flicker which is not noticeable because the pair of LED's are close together.
The flicker I get is as much as a 4 feet Fl. Tube light burning.
This is definitely an AC circuit. Some changes to the design could refine it into two, half-wave sinusoidal DC circuits, where electrolytic caps would be useful.
It's best to use the correct terminology to avoid confusion.
* A single electromagnetic component that increases or decreases AC voltage is a transformer.
* A device that lowers DC voltage is a regulator, a buck converter, or, generically, a DC-DC converter.
* A device that increases DC voltage is a boost converter (also generically a DC-DC converter)
* A device that turns AC into DC is a rectifier
* A device that turns DC in AC is an inverter.
The flicker is more if the distance of the LED's are more.
YOU DO NOT NEED ANY CHANGE
Adding a bridge rectifier will not work on AC.
This is intentionally made for AC current.
WHY DO YOU WANT TO CONVERT IT TO DC
Regarding the flash: Each group of 10 LEDs operate in each AC cycle, 5 in the first half of the cycle and the other in the second half of the cycle. In each group, 5 LEDs are turned off while the other 5 are on and vice versa. So the time when all LEDs are turned off is rather short, with each cycle. They will be turned off during the time the voltage takes to reach the level of polarization that each LED need to begin to radiate light, otherwise 5 LEDs are lit, when the other five are turned off. That time should be fairly short, and in my opinion, the flicker can be considered negligible, and less with the fact that the LEDs are pretty close.
favorite
