Introduction: LED CHRISTMAS TREE ON PLEXIGLAS
Picture of LED CHRISTMAS TREE ON PLEXIGLAS
Here is an instructable of making a simple christmas tree with LED's. It shines a constant light and is powered by 4 1.5 V (AA) bateries.
Step 1: PARTS:
COMPONENTS:
  • plexiglas [225x274] mm
  • 5x yellow LED's 5mm
  • 8x red LED's 5mm
  • 27x green LED's 5mm
  • 1x pushbutton switch
  • 1x battery holder (dimensions about: [63x63] mm for
  • 4x 1.5V AA batteries
  • 40x resistors 190Ω (or close but more)
  • some wires (optional)
  • base (I used a cut piece of wood painted gold)
TOOLS:
  • drill
  • soldering iron
  • spray paint
PROJECT:
Step 2: PLANNING
Picture of PLANNING
Stick a sheet of paper with a project printed on it to plexiglas with double-sided tape.
You can use mine or make your own in AutoCad, Photoshop etc.
Step 3: DRILLING
Picture of DRILLING
Drill holes in indicated points and remove a sheet of paper.
Step 4: PLACING LED'S
Picture of PLACING LED'S
Place LED's inside the holes.
Step 5: SOLDERING
Picture of SOLDERING
Solder the LED's with resistors and connect everything together.
Step 6: INSTALLING PUSHBUTTON SWITCH AND BATTERY HOLDER
Picture of INSTALLING PUSHBUTTON SWITCH AND BATTERY HOLDER
As above. Drill a hole for placing pushbutton switch and fasten battery holder in indicated place. Then solder it with circuit.
Step 7: PAINTING
Picture of PAINTING
Make your own base for LED Christmas Tree and paint the back of plexiglas gold.
Step 8: CLEANING
Picture of CLEANING
Remove the protecting foil cover from plexiglas and voilà! Your LED CHRISTMAS TREE ON PLEXIGLAS is done!
DIY Hacks and How Tos (author)2016-01-04
Great lit Christmas tree design. I like how it is flat enough that you could hang it on the wall too.
Thanks a lot! That's my first instructable. Yeah I planned to do that but I was afraid of short circuit. Building over it's back with another plexiglas could fix that.
About This Instructable
444views
8favorites
License:
More by MarcinŚ9:LED CHRISTMAS TREE ON PLEXIGLAS
Add instructable to:
