LED CUBE 3x3x3
1,040
14
Published
Introduction: LED CUBE 3x3x3
hello guys this is a LED cube matrix of size 3x3x3 which contains 27 eld in total,,,designing such things which is entirely hardwired based you need to check for the amount of +VCc supply be needed by you so that i have used arduno uno (it has 12 vcc pins) as it matchec perfectly for my requiremnent
for further more quires of disccussion mail me on to \\do follow my insatgram page (www.instagram.com/build_more/)
buildmore@gmail.com
Step 1: PARTS NEEDED
wire cutter
soldering ion
soldering wire
pcb holding hand
27 led
arduino uno
data cable
bc547 common transistors
jumper wires single core
Step 2: HARDWARE DIAGRAM
first of all i would suggest you to draw the 3d dot daigram considering them a led for your own better understanding of rows and collumns of led do you dont miss out nayterminal later on it will be hard to solder in between the core part of led matrix once its done
then solder your led to the standing position in yur pcb with 3 cross 3 grid making 9 led on grid
then
there will be such 3 layers in total
as per the daigram
Step 3: CONNECTION
now as mentioned do the soldering and connection of the led cube and
do rember there are three layers of led and as per that the ground of every led is the connected in short circuit manner
in single layer
remember that the ground of the ;layer 1 and layer two is not to be connected
and as you can imagine by now that there will be 9 standing columns
so the positve leg of every led standing in same row is to be short circuited
i have told to separate the layer 1 and layer 2 ground because that will be connected with th three enabling transistors
if i want to blink a led single led then all i ahve to do is provode the vcc to that whole standing row and then select that particular layer with applying vcc in the base terminal of that transistor.
Step 4: THE CODE
here is the code file
you will extract a library file and example file for the led cube just open it by arduino.ide of .ino extension
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
