loading
Step 7: Install LED chandelier
Because this LED chandelier is not as bright as the incandescent chandelier, the best location to install this LED chandelier is in the hallway.
To install your new LED chandelier:
-turn off all power where you going to install the LED chandelier
-use the wire stripper to cut the male plug off the LED string light and strip 1/2" of the two wires (has no ground wire).  Don't cut the female plug on the string light, leave it.
-The two wires have no polarity which means you can connect either wire to positive or negative. Connect either one wire to positive (usually white or red) and other to negative (usually black).
-Secure the LED chandelier like you would for a normal ceiling light.
-after your done, turn the power back on.
-Switch on your new LED chandelier and be surprised.
Nice, but i gotta know.. you seem to have no transformer or resistor etc.. I'm thinking as i sit here with a light socket adaptor and some Xmas lights with a transformer/controller on it... did yours have an adaptor? or are they mains voltage LED's? or do they just work? <br />Magic? <br />any insight appreciated! <br />
Yes the LED string light I used does have 2 transformer built-in. If you goto step 5 and click on the 3rd picture, you will see two transformers (size of your thumb) already built-in with the LED string light. When you cut off the plug, make sure to leave the transformer along.
Ah ha.. nice one cheers!
Sorry for the typo &quot;along&quot;, I meant &quot;alone&quot;. Leave the transformer alone.
Thank You so much! My sister wanted one of these so bad and She loves it! It was very fun and productive!
Glad to heard that
How could one make this brighter? Is there high power christmas LED lights?
I know there are 3-watt LED that use in high-end LED flashlight but those are expensive. I have never heard of a high power chistmas LED lights.
Beautiful! A couple of years ago, I made a lamp using a solar powered LED string - it was an art project, so it was not done to maximize the light. Now you've given me a GREAT idea for a light in our RV!! THANK YOU!!!!!!!!!
The LED string only uses 3 watts. You can totally make it solar powered. Good idea. I would like to see yours when your done.
Is it safe to only hook up one of the wires to the house power? Shouldn't it have a second wire or a ground hooked up? Can someone explain the wiring logic?<br><br>This is a great instructible. I hadn't thought about using a flush mount light like that, the flange plate has enough room in it for the backs of the lights. Working on a panel LED light with xmas lights but it will just be plugged into an outlet.
I think you might had confused about the wiring instruction. The LED light string has two ends. One end is a male plug and the other end is a female plug that is use when connecting a series of light strings together. The male plug has its own two wires (no ground). The wires have no polarity which means you can connect either wires to positive or negative. I hope that helps you.
Ah. Maybe update the instruction? It wasn't quite clear. So just one to red and one to black as normal, no ground. That makes much more sense. :-) <br>
I revised the instruction and now should be more clear.
This is just too awesome. I too have a used and working LED Sting Light, and an LED Flexible Tube light. This is just the perfect method to utilize it. <br>Also i have another suggestion. you get vegetable Stainers that are pan shaped and have holes drilled in them to strain water, i was thinking even that could be used, as they to are in a circular fashion, and also might coz a Petal Pattern.<br>Anyways, this is definitely worth a try. Will post the pictures here once i am done with it.
It might make this project easier if you can find a nice strainer. I would like to see yours when you are done.
I really love this. Would there be an environmental plus in reduced wattage over, say, incandescent or the compact fluorescent?
Most of the LED light strings like this use 2 to 3 watts so there is a power savings. But as he mentioned the light output is somewhat lower than an incadesent fixture.
You are exactly right. I measured the wattage of the LED light string that I used for this LED chandelier and it's 3 watts.
This looks great! I'm thinking of ways I could incorporate the idea into a more traditionally styled chandelier.
That would be nice. I would like to see that too.
good idea <br>thank you
You are welcome. I will continue to bring you guys more cool projects.
I really like this. It would be cool to make a hanging version.<br>
Thanks, I will think about a hanging version.
This is a really nice design!!!
Now I know what to do with all those crystals I bought for my chandelier and didn't use...<br><br>cool.
I love this! Especially the addition of the lights shining out the sides along the ceiling!
I glad you love it. My wife love it too. I made for her as one of her Christmas gift.
About This Instructable
46,682views
196favorites
License:
More by kaway27:Slap in the Face Prank Pringles: Once you prank, you can't stop! A simple way to get cats and dogs off your garden
Add instructable to:
