http://www.instructables.com/id/LED-Chess-Set/
I found it through BoingBoing, but couldn't be bothered making one that looked so flash. I just wanted one to work, quick and easy. So all credit to Tetranitrate for the concept and what follows is a quick and easy solution to get a 'similar' result.
This Instructable shows you how to turn a glass chess set into one with glowing pieces that go out when you take them off the chess board.
It uses:
40 LEDs $7.50 Australia (I love Jaycar - electronics supplier)
a resistor or two Free from junk
some copper wire 2m maybe. Free from junk
glue - I used Crystal Clear Araldyte $17.00 or so. Have heaps left.
a glass chess set $5.00 from toy store
Unwanted phone charger Free from Junk - if you don't have one, a friend will.
Solder Free from around
If you have glue, the rest should be less than $15
Tools:
Soldering Iron (can manage without)
Pliers for twisting wire
Knife for stripping wire
Something to cut wire with
Some soldering is required but if you can't, you could still get a working one by just twisting the wire.
Took me about 4 hours to assemble.
Remove these ads by
Signing UpStep 1Get some copper wire
I got mine by using a cutter knife to slice the edge off some electrical cable and then peel the plastic off to expose the wire.
I then pulled the wire out of the plastic.
Wrapped it around the chess board with about 3cm/1 inch going past the edge of the chess board. I did this to get the correct length.
Cut the wire at the desired length. Remove it from around the chess board and separate the wire into strands. You will need 16 strands of copper wire. The stuff I used had strands about the same thickness as wire in a (twistem, bread tie, freezer bag wire).
For grammar go to ==> www.learngrammar.com !
So that they just make a line with a bit of wire at each end just like the LED has to start with. I don't think it makes any difference which leg or what direction the resistor faces.
One thing it needs - each piece needs ITS OWN resistor to maintain correct power distribution.
Since all the LEDs are in parallel, the formula is pretty simple and there are plenty of online calculators available.
Calculator 1
Numbers you will need: The voltage of your input adapter, likely 5 volts, might be as high as 24.
The forward voltage of the LED, usually around 1.5-2 volts for red, 3 for green and 4.5 for white/blue. Check the spec sheet to be sure you're below the MAX, or you will have a fizzled LED.
The forward current (amps, or milliamps in this case) is how much current the LED can turn into light. Most bright leds dont go above 20-25 mA (milliamps - thousands of an amp). Small 'indicator' leds like those on the front of a vcr rarely exceed 10mA, if not 5mA.
Example:
Input 9 volts DC
LED forward voltage: 2.8 volts
Max current: 15mA
resistor = 470 ohms, 1/4 watt
Plug those numbers in, and you will get a resistor value in ohms (or kilo-ohms). Since you already order your leds online, grab a pile of resistors, 1/4 watt is overkill, you could get away with 1/8 watt
If you can get an AC (Alternating Current) adapter close to your LED voltage you still need the resistors, but it means you can place the pieces either way, without worrying about polarity (+/-) Just make sure the power supply does not exceed the max REVERSE voltage. Thats another story.
Any questions feel free to ask.
