Step 12Making the pieces
Gluing the LEDs - Using the gel superglue I glued sixteen blue LEDs into the clear pieces (I chose blue for the clear pieces because it would resemble ice), and sixteen green LEDs into the frosted pieces. While gluing try to make sure the negative lead (the longer one) is directly in the center of the piece because it will be making contact with the magnet that is in the center of the square.
Trim the leads - Bend the positive lead to the rim of the base and clip the excess, as shown in the picture. Clip the negative lead so that it is just slightly extending past the bottom of the piece, and bend the excess at a 90 degree angle, so it will have some area that comes in contact with the magnet.
Glue the washers on - I covered 3/4ths of the bottom of the chess piece with glue. The remaining quarter was the area near the positive lead. I left it unglued because I did not want to risk ruining the connection to the washer. Firmly press the washers onto the glue (but do not rotate!) and let sit undisturbed until the glue is dry.
Solder the lead - Solder the positive lead from the LED to the inner rim of the copper washer. This will be a delicate, slow going operation, but be patient and do each one carefully.
YOUR FINISHED!!! - Plug the board in, and put the pieces on it to make sure they all work. Sit back and bask in your awesomeness which is a direct result of my awesomeness.
On the other hand, this would allow you to use colored plastic with all white leds, or use the 'superflux' type of leds, especially if using the copperclad board I suggested earlier.
Again, hats off to your inovation.
All in all, however, a MOST excellent idea and instructible.
in single colours it's always long = + short = -
so dan is prolly right, (s)he wired the power suply backwards
