Enjoy, and please, please take that one minute to rate, comment and vote!
Remove these ads by
Signing UpStep 1You will need:
People outside Australia, I'm not sure where you can buy this. If you can't find it at any stores, your best bet is probably to order online. I got mine from Myer. You CANNOT get this outside of Christmas time, unless you can still order online or off eBay.
15 LEDs
I got a $12 Digitor 50 pack of 5mm LEDs from Dick Smith Electronics. Again, you Americans can probably get LEDs from RadioShack or something. You can use whatever kind of LEDS you like, as long as it isn't IR.
Batteries to suit your LEDs
If you're using 5mm regular (not super bright, flashing or RGB) LEDs, you could just use 4 AA or AAA batteries connected in series to make 6v. Depending on your combo of LEDs and batteries, you may need to buy resistors.
Electrical or masking tape and clear sticky tape (not pictured)
Medium to fine grit sandpaper (not pictured)
Either a small metal rod (I used an ear cleaner) or a soldering iron (not pictured)
A needle or thumbtack (not pictured)
Blu-tack or hot glue (not pictured)
32 lengths of about 15cm long, thin wire
comments
Add Comment
Add Comment
